Results 1 to 20 of 3899
    Quote Originally Posted by Rocko24 View Post
    There are filter heads with indicators that tell you when the pressure drop between the inlet and outlet is beyond a certain limit.
    I don't know if these are available for small filters though. I have only seen them for big hydraulic filters.
    [IMG][/IMG]
    Nice. May I ask what brand this is? Worth a look.
    Mar 2005
    Next oil change ko sa Jazz and Rav4, I will crack open RP Filters... Any advise kung paano siya i open?
    Jul 2011
    Quote Originally Posted by jmpet626 View Post
    lagariin mo?
    May 2005
    Use a saw if you don't want to ruin the inside. Use an electronic grinder for quicker and less effort cuts but do so with caution since it could damage the filter inside.
    A vise is to grip and hold down the filter while you cut.
    There is a specific tool for opening oil filter canister but you can use:
    Hacksaw
    Pipe cutter
    Metal scissors
    Cutting disk using electric/pneumatic Rotary tool/ die grinder like dremel, B&D RTXB, makita gd series, IR3000series.
    Band saw
    Lathe
    Cutting disk and sawing leaves lots of metal-dust residue, better use this with dust extraction tool or paint brush.
    I'm using 5" pipe cutter for cleaner cuts.
    Sep 2013
    Napansin ko pag oil filter lagi pinaguusapan baldwin, donaldson and fleetguard.
    Pag i-rate sino top 1,2,3?
    Saan din distributor ng donaldson and fleetguard?
    Quote Originally Posted by chookchakchenes View Post
    Tingin ko sa Donaldson, Gigatrade/Volmax. Yun Fleetguard, yun nasa New Manila. Di ko lang maalala yun distributor
    Sent from my GT-N7100 using Tapatalk 2
    Aug 2013
    Lower priced ang Baldwin compared sa Donaldson/Fleetguard and readily available ang filters need ko.
    Baldwin - available sa Volmax - Binondo, Gigatrade - Grace Park, Caloocan City at Durasales - C3
    Donaldson at Fleetguard - available sa W & L - 8th St, New Manila at Durasales - C3
    May 2005
    W&L did not have all of the Fleetguards I was looking for but the other shop had it. W&L is also selling the "fake" LF3564.
    Mar 2012
    These are the distributors of the 3 filter brands:
    1. Baldwin - Volmax is the distributor.
    2. Fleetguard - Cummins Philippines and Pacer are the distributors.
    3. Donaldson - Paleeno, Highland Tractor Parts, Hino Parts Specialists, Prudential Intertrade.
    Sep 2013
    xie xie
    Pag malayo sa mga place na yan dapat by the dozen ang bili. Ang traffic papunta sa volmax at maghanap ka parking pa na obviously magbabayad ka pa 30 - 50pesos rate para sa 15minutes na transaction.
    Mar 2012
    The filter head is a Donaldson P563268. It fits filters with thread size 1-1/2" - 16 TPI. Much too big for our regular car oil filters.
Remote bypass oil filtration
