Page 167 of 195 FirstFirst ... 67117157163164165166167168169170171177 ... LastLast
Results 3,321 to 3,340 of 3899
    Jul 2011
    #3321
    parang walang gumagamit ng remote bypass sa thread na ito meron ng namimili sa US pero wala yata nagpo-post ng remote bypass filter project.
    #3322
    Quote Originally Posted by MrQ5 View Post
    gusto ko sana gawing project yan sa 4m40 ko. kaso hindi kasi common yung filter thread size ng 4m40 kaya walang off the shelf na kit.
    Jul 2010
    #3323
    Dapat palitan na lang yung thread title.. "Oil/fuel filter" hindi uso dito remote bypass.. Hard to find mga ganyan filters
    Dec 2009
    #3324
    tried maghanap ng resources for the bypass filtration both for the engine and AT transmission... sumakit lang ulo ko kakatawag at hanap... walang mga adaptor, head, at filter para sa application.... medyo madame ka ipapa-fabricate...
    unlike sa abroad na meh direct at exact kit para sa application..
    sir bayen wala bang BD28 ngayon sa volmax? pm mu naman number mu sakin, meh itetext ako sayo...hehe
    Jun 2004
    #3325
    Hi Doc. It's been a long time since I posted in this thread. Noticed that there are more people now who are benefitting from better filters. Anyway wanted to ask if there's a Baldwin equivalent for the OEM Toyota filter for the LC 200 engine - 1VD-FTV? I'm still using the OEM filter.
    And to Bayen and Miko - do you have stocks of BD 28? I'm on my last piece na. Thanks.
    #3326
    Quote Originally Posted by paj4x4 View Post
    What's the filter part number of the 1VD?
    Jan 2012
    #3327
    eto yata idol. part no. P7406
    JS Filters :: Application Cross Reference and Image for JS : Oil (Element) : OE0071
    #3328
    ^Cartridge type na rin. Malamang wala nyan dito. Upside is it's fairly easy to carry in from abroad if you have relatives flying in.
    Jun 2004
    #3329
    Thanks Bayen and Vinj. Yes it's a cartridge type. I checked out the link wala pang magandang alternative. Hopefully maganda filtration properties ng OEM Toyota. Anyway I stick to a 5k km OCI
    #3330
    Yep, OEM is fine with your usual 5K interval; Motul CRDi synth pa yung gamit so that's even better than the TGMO.
    Jun 2004
    #3331
    Thanks again Vinj.
    May 2005
    #3332
    Will upsizing to a longer and a bit wider (rubber gasket same diameter) oil filter affect the oil pressure negatively ?
    I have gone from Toyota OEM 90915-YZZD2 to LF3487 (present) and soon LF3947.
    Jul 2010
    #3333
    Is it for d4d engine? B178 baldwin is what you want
    May 2005
    #3334
    Quote Originally Posted by TheGreenThing View Post
    Its for the VVT-i. There is a ton of space down there. Fleetguard is still to go for me in this my case.
    This one's my photo.
    photo credits to devil doc
    LF3487 on the right. LF3947 on the left.
    #3335
    I dont think so sir. Psid are very far.
    Jun 2005
    #3336
    dvldoc
    Re: Remote bypass oil filtration
    Parts masters are about as good as wix so 10000klm is no problem. for the td27 I would use the B7022 you can find it. its also the same filter for the Td42 engine. These engines to include the QD series have internal bypass valves so u can't us a B2.
    I would also find a better oil that oils tbn is crap. You want at least a 10 for the tbn. I would for a good diesel oil that has under 1200ppm phosphorus so u can use it in gas engine. you will get way more engine protection.
    *dvldoc
    Sir can you please enlighten us why we cant use B2 for QD32,TD27 and TD42 engines as you stated above?since B2 is the equivalent also of LF551A.TIA
    Dec 2007
    #3337
    Because nissans have the oil bypass in the engine, You have to use a filter without a internal bypass valve on those nissan engines. So there is no way of knowing what the stock bypass setting which i have tried to find out, it should not make a difference because either one will send it into bypass mode, there would be no oil starvation issues but I prefer to use the correct filter set up.
    Jul 2010
    #3338
    What baldwin is the best application for my adventure 2011 model ?
    Prefer oversized yet fits perfectly on the slot
    Thanks
    #3339
    Thanks
    For gas, b1402
    For diesel, bd28
    Jul 2011
    #3340
    may gas variant na ba ang adventure ngayon?
