parang walang gumagamit ng remote bypass sa thread na ito meron ng namimili sa US pero wala yata nagpo-post ng remote bypass filter project.
Dapat palitan na lang yung thread title.. "Oil/fuel filter" hindi uso dito remote bypass.. Hard to find mga ganyan filters
tried maghanap ng resources for the bypass filtration both for the engine and AT transmission... sumakit lang ulo ko kakatawag at hanap... walang mga adaptor, head, at filter para sa application.... medyo madame ka ipapa-fabricate...
unlike sa abroad na meh direct at exact kit para sa application..
sir bayen wala bang BD28 ngayon sa volmax? pm mu naman number mu sakin, meh itetext ako sayo...hehe
Hi Doc. It's been a long time since I posted in this thread. Noticed that there are more people now who are benefitting from better filters. Anyway wanted to ask if there's a Baldwin equivalent for the OEM Toyota filter for the LC 200 engine - 1VD-FTV? I'm still using the OEM filter.
And to Bayen and Miko - do you have stocks of BD 28? I'm on my last piece na. Thanks.
eto yata idol. part no. P7406
JS Filters :: Application Cross Reference and Image for JS : Oil (Element) : OE0071
^Cartridge type na rin. Malamang wala nyan dito. Upside is it's fairly easy to carry in from abroad if you have relatives flying in.![]()
Thanks Bayen and Vinj. Yes it's a cartridge type. I checked out the link wala pang magandang alternative. Hopefully maganda filtration properties ng OEM Toyota. Anyway I stick to a 5k km OCI
Will upsizing to a longer and a bit wider (rubber gasket same diameter) oil filter affect the oil pressure negatively ?
I have gone from Toyota OEM 90915-YZZD2 to LF3487 (present) and soon LF3947.
dvldoc
Re: Remote bypass oil filtration
Parts masters are about as good as wix so 10000klm is no problem. for the td27 I would use the B7022 you can find it. its also the same filter for the Td42 engine. These engines to include the QD series have internal bypass valves so u can't us a B2.
I would also find a better oil that oils tbn is crap. You want at least a 10 for the tbn. I would for a good diesel oil that has under 1200ppm phosphorus so u can use it in gas engine. you will get way more engine protection.
*dvldoc
Sir can you please enlighten us why we cant use B2 for QD32,TD27 and TD42 engines as you stated above?since B2 is the equivalent also of LF551A.TIA
Because nissans have the oil bypass in the engine, You have to use a filter without a internal bypass valve on those nissan engines. So there is no way of knowing what the stock bypass setting which i have tried to find out, it should not make a difference because either one will send it into bypass mode, there would be no oil starvation issues but I prefer to use the correct filter set up.
What baldwin is the best application for my adventure 2011 model ?
Prefer oversized yet fits perfectly on the slot
Thanks
