dvldoc
Re: Remote bypass oil filtration
Parts masters are about as good as wix so 10000klm is no problem. for the td27 I would use the B7022 you can find it. its also the same filter for the Td42 engine. These engines to include the QD series have internal bypass valves so u can't us a B2.
I would also find a better oil that oils tbn is crap. You want at least a 10 for the tbn. I would for a good diesel oil that has under 1200ppm phosphorus so u can use it in gas engine. you will get way more engine protection.
*dvldoc
Sir can you please enlighten us why we cant use B2 for QD32,TD27 and TD42 engines as you stated above?since B2 is the equivalent also of LF551A.TIA
