Because nissans have the oil bypass in the engine, You have to use a filter without a internal bypass valve on those nissan engines. So there is no way of knowing what the stock bypass setting which i have tried to find out, it should not make a difference because either one will send it into bypass mode, there would be no oil starvation issues but I prefer to use the correct filter set up.
