Results 1,231 to 1,240 of 3899
February 20th, 2012 11:17 AM #1232
February 20th, 2012 11:45 AM #1233
doc, i also noticed that the baldwin BD28 is shorter than the OEM oil filter for the 4M40. should i worry on this?
February 20th, 2012 11:49 AM #1234
No because it has more filter media and it has a superior filter media, the height on a filter is not a big deal. It's the number of pleats a filter media has and the efficiency it has is the important part.
February 20th, 2012 11:53 AM #1235
http://commercial.jcprimo.com/pdf/Mo...acing%204T.pdf
Not to impressed with there synthetic oil, add package is pretty weak and so is the TBN
http://commercial.jcprimo.com/pdf/Au...otor%20Oil.pdf
http://commercial.jcprimo.com/product.html
There diesel oil however looks pretty good, all their synthetics are group III.
http://commercial.jcprimo.com/pdf/Au...0Syn%20100.pdf
http://commercial.jcprimo.com/pdf/Au...gine%20Oil.pdf
I'll look into there additives later.Last edited by dvldoc; February 20th, 2012 at 12:01 PM.
February 20th, 2012 12:26 PM #1237
Looks like there powermaxi additive is concentrated ZDDP, to bad none of there data sheets shows the percentage. They do unfortunately give it that BS nano technology marketing. But it's just ZDDP.
February 22nd, 2012 02:06 PM #1238
just replaced the lower tensioner bearing on my truck and the oil pressure light shuts off quicker now (as when i was using a vic)...
February 23rd, 2012 12:06 PM #1239
Found it on the net, don't know if this will be helpful.
http://www.oilman.com.au/wp-content/...ison-Chart.pdfFasten your seatbelt! Or else...Driven To Thrill!
February 23rd, 2012 12:18 PM #1240
Yes, i do think so. Since it's based on the 4th-gen delica/space gear, which in turn shares some of...
Mitsubishi Philippines
