Page 124 of 390 FirstFirst ... 2474114120121122123124125126127128134174224 ... LastLast
Results 1,231 to 1,240 of 3899
    #1231
    Your company really should look into running the oil longer, and saving some money. Here is a used oil test at 4000kms on Delo.
    Nice find, will present this data to the owner so we could extend to at least 4 mos.
    #1232
    Yeah, that will save you on one oil change per year.
    #1233
    doc, i also noticed that the baldwin BD28 is shorter than the OEM oil filter for the 4M40. should i worry on this?
    Dec 2007
    #1234
    No because it has more filter media and it has a superior filter media, the height on a filter is not a big deal. It's the number of pleats a filter media has and the efficiency it has is the important part.
    Dec 2007
    #1235
    Mga masters, just want to ask if you have any idea about this oil company?
    http://media.jcprimo.com/permalink/A...0Catalogue.pdf
    I'm talking specifically Primo Grand Racing 4T oil.
    http://commercial.jcprimo.com/pdf/Mo...acing%204T.pdf
    Not to impressed with there synthetic oil, add package is pretty weak and so is the TBN
    http://commercial.jcprimo.com/pdf/Au...otor%20Oil.pdf
    http://commercial.jcprimo.com/product.html
    There diesel oil however looks pretty good, all their synthetics are group III.
    http://commercial.jcprimo.com/pdf/Au...0Syn%20100.pdf
    http://commercial.jcprimo.com/pdf/Au...gine%20Oil.pdf
    I'll look into there additives later.
    #1236
    PRIMO Trusted Maintenance Products
    As always, you're the man!
    Dec 2007
    #1237
    Looks like there powermaxi additive is concentrated ZDDP, to bad none of there data sheets shows the percentage. They do unfortunately give it that BS nano technology marketing. But it's just ZDDP.
    May 2009
    #1238
    just replaced the lower tensioner bearing on my truck and the oil pressure light shuts off quicker now (as when i was using a vic)...
    #1239
    Found it on the net, don't know if this will be helpful.
    http://www.oilman.com.au/wp-content/...ison-Chart.pdf
    #1240
    RT, the oil filter for our rig is BD28 right? how about the fuel filter?
Remote bypass oil filtration
