Page 45 of 195 FirstFirst ... 354142434445464748495595145 ... LastLast
Results 881 to 900 of 3899
    been looking for strap wrench everywhere. pati sa Ace, True Value wala. ended up ordering abroad nalang hehe
    this is what i got. 2 pcs. rubber strap wrench
    Ayos ah! Pang-oil nd fuel filter.
    Jan 2011
    #882
    I think this is pretty clear now Someone has replace the filter head with a non Mitsubishi unit. They basically look exactly the same but have a different thread. So they just matched the filter that was on the vehicle when they changed it. They both are the same flow pattern so it should really make no difference using the different filter head.
    Appreciate much your inputs Doc. Had checked my friend's Montero Sports and it all used the Denso 186100-6080 fuel filter as well. Actually checked my colleague's rigs as well and all uses the same type of fuel filter. Even some well known auto parts stores also gives out the Denso type when asking which one is fitted for the MS.
    Don Cross of Baldwin also confirmed that the BF7535 is the cross for the Denso 186100-6080. Tried to check the thread pattern and it really seems that the BF7534 would fit also as the BF7535 3/4-16 thread is only 0.068" smaller than the M20-1.5 thread of the BF7534. It will only boil down to the the maximum pressure the fitting can withstand.
    Sadly, will need to wait until mid-January to get this all tested. No more stocks from Volmax for both.
    Jun 2007
    #883
    seems like there was somekind of buying frenzy that hit volmax....
    called them a month(mid october) before I got my fuel filter to confirm availability, told me it was abundant then suddenly now its out of stock...
    Jun 2007
    #884
    BTW here's another proof that the fleetguard I got was a Knock off!
    heres the fake one when it was still new with its box
    here's an original one, I got this pic from EBAY its being sold for 24$
    if you look at it closely even the size was quite different...the fake being the bigger and the smaller one is the original...
    and notice the markings on the filters? BALIKTAD!!! hahaha! I do hope you understand the word doc
    You'd be the judge!
    and the boxes, hehehe the knock off was too nice! and the original was simple but it has the MADE in USA text that made all the difference
    Dec 2007
    #885
    There is a size difference because what I pointed out a few post back, that is not a dual element filter it should be a full flow and have just one filter element in it. The fake also appears to be fluted which the original is not.
    Shame on those who sell fake Fleetguard filters clear your bad stock and replace it with filters from the manufacture your supposed to be the official dealer for.
    Fleetguard has now updated there site to put new images of their filters that are in adobe flash and you can rotate them 360 degrees and see every angle and side of the filter they did it to make fakes easier to spot.
    Cummins Filtration - Catalog - Catalog Map just enter your filter number and take a peak.
    Yeah Volmax is selling the Baldwins left and right, at least more people know about getting good filters hoped they ordered enough on there next shipment to keep up with demand.
    Dec 2007
    #886
    For you ZD30 Patrol guys and Elgrands Baldwin does make a filter for you as well.
    Baldwin P7365
    Compare to vic and OEM
    #887
    hi doc!
    the BF7534 is a good fit to the 4m41 according to KCboy
    and I can attest to that...
    My question now is that do fuel filters differ from oil filters when it comes to fitment?
    meaning, as long as it bites the thread well, were good to go? or it does not apply the same principle?
    so even though if it fits well as long as its not the same as the one in the cross reference sheet indicating that it does not have the same bite as the OEM, its not good and leaks are imminent?
    because I already traveled about 400kms with it and so far I didn't experience anything unnecessary....and its all good...
    I just wanted to have your approval on this... thanks doc!
    i've travelled 1600kms already since i changed to the baldwin fuel filter last august 2011, i didnt notice any difference,
    i also added 2t whenever i refuel. you should be ok.....kung may masisisra, baka maunahan na kita.
    #888
    and just in case your wondering what I've put in after the guinea pig test....
    I didn't take chances anymore and went for the best....:bwahaha:
    I just had a minor glitch on it...because the mechanic was a bit hesitant on pressing on it a bit to reach the thread....but with a little force voila! a perfect fit....
    and with this flowing on it....
    and with that, the RIG is kicking like a young stallion again...=)
    sir,
    parehong pareho na strada natin, from the oil, oil filter all the way to the fuel filter.heheheheh
    thanks to you and dvldoc for this thread and i wad able to decide on switching to baldwin filters, lower price but better quality.
    im luck i just live 1 minute walk from volmax.
    Dec 2007
    #889
    4M40, 4M41 AND 4D56 guys can also use the BD7028 if they are out of stock of the BD28 the main difference is it's just a little bit longer and a little bit bigger in diameter but fits perfect.
    Jun 2007
    #890
    Quote Originally Posted by KCboy View Post
    thats good to know sir... knock on wood sana wala namang masira hehehe about the 2t naman, kamusta ba sir? may napansin ba kayung difference or what? kasi yung mga kasama natin sa TSCP was descouraging me very well....sa mga dumptruck lang daw nila ginagawa yun.....
    sir,
    hehehe....actually sir to be honest, I've waited for somebody who would try the product first, sakto namang naswerte ako na may una ngang sumubok at nadoble pa lalo dahil naka strada rin..... so thanks to you talaga! di lang ako nasatisfy nakatipid pa ko....
    BTW, Advance Merry Christmas to the People of this thread!
    Jan 2011
    #891
    Hi Doc, currently using Royal Purple 15W-40 paired with BD28. Performance is good but still looking for alternatives. Plan to use Fleetguard LF3564 next but still undecided on the oil. Which is comparable or better than RP? Mobil 1 TDT, Mobil Delvac MX or Motul (?)...TIA.
    #892
    Quote Originally Posted by tuazon7 View Post
    Bro how much per liter ng rp? Fully synthetic?
    #893
    Quote Originally Posted by zix888 View Post
    Royal Purple nasa 600 per quart. It's a Group 4 oil.
    zix, kung gusto mo bang for the buck oil, Top1 SDO suggest ko sayo. may post si dvldoc regarding that sa thread na ito. ok na oil din daw yun. semi syn. 280 per quart.
    #894
    Gusto ko sana fully synthetic. Yung mobil 1 TDT okay din daw base sa thread na ito. What do you mean by group 4? Thanks bro
    Dec 2007
    #895
    Well if you find a real LF3564 let everyone know were you got it, remember no country of origin it's a fake. The LF3564 is also now being made in Argentina as well. Mobil1 TD has a much better additive package over RP.
    In a Turbo diesel it's all about the oil with the most Zinc, Phosp, Moly and Boron and Calcium and who has the highest TBN, all will give you longer oil life.
    Mobil1 0-40
    Royal Purple 0-40
    Feb 2007
    #896
    Does Baldwin BF7534 fit the 4D56?
    Feb 2007
    #897
    Where did you bought your RP? Bought mine at Hans Tools in Shangri-la for 640 each.
    #898
    Quote Originally Posted by freeloader View Post
    speedyfix
    The message you have entered is too short. Please lengthen your message to at least 10 characters
    #899
    if you have money to burn, maganda nga fully synthetic. but remember, even if you are using fully synthetic, it is still best to change oil every 5k km for diesel engine because Philippine traffic is considered extreme driving conditions. stop and go traffic + the heat + dust.
    Jun 2007
    #900
    yup....thats for the commonrail BTW...Im not sure about the non commonrail...
Remote bypass oil filtration
