Results 1 to 20 of 3899
    *dvldoc
    The LF3487 doesn't fit the Navara (Thai built one at least). A friend tried fitting one in and it wouldn't. Kinda disappointed, the thing was bigger and heavier than stock and looked to be more heavy duty. LF3400 is much smaller in comparison.
    Some of the stock from the dealer in Caloocan were old, produced 2007. Quite a few had rust on the bottom end, have to look out for that. And yeah, they do try to sell the fakes along with the originals.
    ^ grabe yan ah, side by side selling ng orig and fakes?!
    oo nga someone should report it to fleetguard with a picture of the fake attached
    Dec 2007
    They are much more heavy duty, To bad it will not fit. It's probably a bit to tall for your engine.
    *dvldoc
    You may try similar OEM size like LF689, B223, B229.. LF3400 is heavy for its size, i guess element density is thicker..
    Here's some weight comparison of our lube filters..
    And the Primary Fuel Filters.. OEM is heavier than the rest of the ripoffs.. hehe
    And most importantly the gasket is 2grams..lolz..
Remote bypass oil filtration
