Some pics of my remote bypass dual oil filter set up.
Consist of dual remote base
Oil filter adapter for adding oil pressure and oil temp gauges, senders are in place
Remote oil drain to check oil samples from time to time without crawling under the van
AN fittings installed
I added grip tape to my filters to make changing them easier, shouldn't need a bulky oil filter wrench.
I am going to go with 1/2 hydraulic hose just because I can get it cheap from surplus
Spin on oil filter adapter that goes where the stock oil filter use to.
And a handful of old hard drive magnets (super super strong) I want to catch everything
Also pictured is my remote transmission oil filter. Gives me about 50 times better filtration over the stock tranny metal mess strainer.
Of course this system is a bit extreme but I wanted to play around with it anyways.
You can also go with a remote mount filter using one of these spin on adapters especially if you have a turbo diesel with a little baby filter like the D4D engines and Navara pick-ups. You can add a much larger filter for better flow and filtration and much longer oil change intervals.
I plan on changing my primary filter at 15000klm and secondary at 30000klm oil at 20000klm.
First filter cleans down to 5 microns second which is the Fleetguard Stratopore media cleans down to 2 microns so it will basically never see any particles over 10 microns due to the first filter.
Yeah it's over kill but since I am not in to Rims and bling best to spend on something that will make your ride last longer and reduce maintenance cost. I ended up with 4 extra universal spin on adapters that fit just about any vehicle probably sell them next year when I am actually back there.
All together a set up like this for the dual bypass system cost me about 160USD cause I shop around. Just need to add my teflon tape and tighten everything down.
