Page 120 of 200 FirstFirst ... 2070110116117118119120121122123124130170 ... LastLast
Results 2,381 to 2,400 of 6586
    Jul 2015
    Business kasi kami kaya factor lowest price, current ratings.
    Ngayon sa business we alternate valvoline, zic, castrol. Subok na namin.
    For our personal car gamit ko for gasoline engine zic a+, castrol edge, synpower. Pag pumunta pinsan ko sa america sa kanya ako nagpapadala yung mga hindi available na oil locally pero hindi practical kasi problem consistency sa pag gamit.
    So kung sa metro manila ka bibili advice ko pinalowest price na rated dexos 1, ILsac gf-5, api sn for gasoline engine.
    Apr 2014
    Quote Originally Posted by SkyFlakes88 View Post
    Sir since you have quite an experience with oils could you recommend what oil can i try with my ride po? I am now using shell helix 5w/40 in my car. What other brands can you recommend po that is better for gas fed engines sir? Thank you [emoji4]
    Sir, ano po auto nyo? Pwede mo rin po check sa owner's manual kung ano po ang SAE viscosity at API rating ang recommended. Then later saka natin pag usapan ang brands.
    Quote Originally Posted by trucker111 View Post
    just want to give my feedback on delo 400.
    change oil 2 weeks ago using delo 400. drove 100km since....
    I say very disappointing. hindi madulas, mas umingay yung engine.
    problem is... there's still 4900km to go
    i'll give it 2/10
    What was the oil before?
    Mar 2011
    On Top 1 SDO for 40k km already.
    Aug 2009
    Currently trying Pertua's Exello oil for diesel engine. So far smooth even on start ups and ok acceleration.
    Quote Originally Posted by Lew_Alcindor View Post
    My Innova currently have Delo Gold in it.
    Coming from Toyota Fully Synthetic, I'd say it is good in its first 1000kms.
    I have to see if it will maintain its performance until the next oil change (after 3,500kms or 4 months). Yes, I am experimenting on 3 oil changes in one year (instead to two) using mineral oil.
    Please keep all receipts also an excel file hehehe. Its tedious but well worth the information and good when its time to sell the vehicle.
    Jul 2013
    I already have a record book. I just need to write the necessary stuff. I did it with my old corolla.
    Jun 2012
    Sir amoyligo,
    Mobil 1 tdt 5w40
    Or
    Zic x7 10w30?
    Jul 2015
    Quote Originally Posted by dct View Post
    Sir amoyligo,
    Mobil 1 tdt 5w40
    Or
    Zic x7 10w30?
    Depende sa price.
    Ano price? at ano api nung tdt 5w40?
    Apr 2012
    Sir amoyligo,
    Mobil 1 tdt 5w40
    Or
    Zic x7 10w30?
    X7 should be enough. Given na CI-4 sya. Compared to TDT na CJ-4 which is more compatible for low sulfur diesel operations
    Jun 2012
    Quote Originally Posted by amoyligo View Post
    Depende sa price.
    245 zic
    440 mobil 1
    Paired with baldwin, pwede rin ba 10k km interval ang change oil with zic? Ganyan kasi gawa ko sa mobil 1
    Jul 2015
    245 zic
    440 mobil 1
    No contest ang layo ng price. Mag zic ka.
    Sa gasoline engine sisiw yan 10,000kms,
    Pero sa diesel practice namin sa negoyso around 7,500kms nagpapalit na. So not too early not too late ang palit ng oil.
    Jun 2012
    Thanks for inputs sir. Kahit pa baldwin ang oil filter? Delikado ba 10k para sa zic oil?
    Sir Nissan Sylphy po manual. Sa manual po recommended 10w/30 but nun nag Pms po ako 1k nilagay nila elf 5w/40 then sa 5k at 10k pms ako na nagdala oil ko shell 5w/40 till now yun na gamit sir. I'm thinking po next yun castrol na brand po e. Your inputs are highly appreciated sir. Ty
    https://youtu.be/O1hF25Cowv8
    You brought shell? Helix Ultra? Thats fully synthetic oil. its one of the best oils.
    Shell Helix Ultra is fully synthetic(silver bottle)
    Shell helix HX7 semi (blue bottle)
    Shell helix hx5 premium multigrade (yellow)
    Mar 2015
    Sir eto po yun oil na gamit ko. D ko po kasi gaano naintindihan sir yun mga rating e. Pasensya na po. Basta sabi po kapatid ko ito daw lagay ko e. imageuploadedbytsikot-forums1439993747.002886.jpg
    Quote Originally Posted by midnytwarrior View Post
    Kung makakahanap ka ng oil na 10w30 na synthetic, or Castrol Edge na 10w-30(not sure if meron dyan sa atin). Make sure to buy sa mga reputable na sellers and at least check mo if API SN na sya para at least bago yun oil. Kung may naka stamp na manufacturing date mas OK.
    Lahat ng engine oil meron manufacturing date. There is a shelf life for these oils.
    The Ford 1.0L Ecoboost engine requires 5w20 A5/B5 synthetic oil. Sad to say that local Ford casa don't carry such an oil. The only viable replacement, as per the manual, is a synthetic oil with 5w30 oil. Ford Manila Bay uses Shell Ultron 5w30.
    Sa sunod kung out of warranty na, gagamitan ko na ng 5w20 synthetic or maybe 0w20, similar to what Subaru suggests for their turbo engines.
    Mar 2012
    I always thought that oil never expires until i read this. So I checked my leftover containers. Honda SS oil has 2014 printed on it, no indication if it is manufacturing or best before date. However it did feel good on my engine. The other one was Mag1 FS, unfortunately the printed numbers were almost worn out so can't get anything from there. it's currently on my engine for 1k kms now and it feels a bit rough compared to the Honda. Both are SN rated.
    Sep 2013
    I've tried several times using expired FS oil 3 years from the mfgt date. so far nothing bad happened to the engine. What's the effect of using expired oil to engine?? TIA
    0w20 is for winter climates. 5w20 is good enough. Shell doesnt have "ultron" products but petron does have ultron products.
    Shell helix ultra 5w30 is very good. I would use that with confidence.
Mineral , semi synthetic or fully synthetic?
