Page 318 of 330 FirstFirst ... 218268308314315316317318319320321322328 ... LastLast
Results 6,341 to 6,360 of 6586
    Apr 2005
    #6341
    Anong kotse ba nilagyan?
    2014 Altis
    #6342
    2014 Altis
    Kaya naman pala. Most small displacement gas NA engines only require a gallon of engine oil. Exception yung mga turbocharged gas at turbocharged diesel engines, mostly sobra sa 4L ang kelangan.
    Oct 2009
    #6343
    that's what the dipstick is for... to check engine oil level.. remember to let the engine warm up and reach operating temp, park the car on a flat area, turn off engine and measure. should not exceed the full mark.
    Usually sa toyota otis ako nagpapa PMS but last year nung pandemic, nag close sila so sa independent shop ako nagpa PMS. The first time na nag change oil sila, ginamit nila 4.5 qts like the casa. So a few months after, bumalik ako for PMS again with the excess oil from my first visit. Nagulat ako na hindi nila ginamit kasi puno na daw. Pagka uwi ako nag buhos ng oil sa engine. Fast forward 3000km and nagka leak yung oil filter ko everytime isastart engine. Lesson learned na sundin dapat ang dip stick haha. Buti na lang hindi na hindi nag leak yung gasket ng engine.
    Pero yung nangyari ba sa akin, ibig sabihin hindi lang na drain ng maayos yung oil kaya 4qts lang nailagay nila?
    #6344
    Sa casa noon, ang mag pms ng auto ko yung assistant. Pag top up lang w/o a change of filter, around 1/2 lit lang kailanga. Inubos ba naman 1 lit. Lampasan sa F ng dipstick. Masama sa makina yun kaya hinigop ko ng straw. Ok lang kung between L & F.
    Jan 2008
    #6345
    Quote Originally Posted by mousemouse View Post
    leak sa oil filter gasket? baka fake yung oil filter na naka kabit? or hindi nahigpitan ng ayos or nalinis yung oil seat sa engine..
    Oct 2009
    #6346
    Vic yung oil filter. Yung leak niya kada start ng engine mga ilan drops lang. napansin ko lang sa garahe na may naiiwan. Nung chineck ko sa dipstick ang layo ng lampas nung oil level. Dapat pala hindi ko na binuhos yung naiwan na oil.
    #6347
    when i change oil,
    i specifically specify, "gravity lang po. no flushing, no compressed air."
    it takes them 15-30 minutes to drain my engine.
    nagdadala lagi ako ng reading material.
    Feb 2019
    #6348
    Anyone recently bought Hyundai xteer ultra gasoline oil? Is it now API SP because last year when I bought it is still API SN.
    Aug 2019
    #6349
    API SN pa din yung nabili ko last month sa Shopee
    #6350
    I have used the Xteer Ultra 5w30 on the ASX for two years now. Late last year I bought some to refill my stocks and the 6L containers already is API SP. The 4L container is still API SN.
    Jan 2009
    #6351
    when i change oil,
    It takes longer than that for all of the used oil to come out. Compressed air helps accelerate things. It's still not perfect. If it were up to me, I'd leave it dripping through the night but this is obviously not possible when done at a shop, so compressed air is good enough.
    And if you're worried about the compressed air contaminating the inside of the engine, rest easy that it won't matter. The by-products of combustion is filthier than outside compressed air can ever be. Also, the inside of the engine is turbulent and whatever trace residue that remained (water vapor, etc.) will be out of the PCV plumbing just a few seconds after the engine has started. All the rest will be burned off as the engine warms up.
    Feb 2019
    #6352
    I see. I ordered the 4L and the seller took a photo and it is indeed API SP for the 4L.... Im satisfied with Xteer for now maybe will try another oil brand for my next oci.
    #6353
    I am satisfied with the Xteer diesel 10w30 CI-4 oil for my 2014 Accent. My only regret is, because of this lockdown, I had to extend my o/c a bit longer than I had wanted & the summer weather is a bit too hot this year for the oil. Good thing Inhardly get stuck in traffic.
    Aug 2012
    #6354
    anyone using amsoil diesel oil? how does it perform?
    thanks
    #6355
    Quote Originally Posted by soullinker20 View Post
    thanks
    We tried the Amsoil Diesel Euro formula for the Jetta TDI. Aside from the casa, only Amsoil we found to meet the oil requirements of the VW TDI engine. Oks naman.
    Aug 2012
    #6356
    thanks. excited to use mine sa 2012 strada. sinusulit ko lang casa oil before i change.
    Mobil now has an official distributor in the Philippines
    topgear writer doesn't even mention the lazmall. "Journalist" kuno
    with the pricing of mobil, I'd rather go with Zic or Amsoil.
    https://www.topgear.com.ph/news/indu...ef=home_feed_1
    Apr 2012
    #6358
    Using Delo 400 MGX for my Grand Starex and Hiace
    Shell HX5 for my vios.
    Performs well so far
    Sent from my SM-A507FN using Tapatalk
    Hx5 ftw. Its what I've been using. 4L jugs are dirt cheap lol.
    Mar 2021
    #6360
    Just found out na at least CI-4 rating na pala ang Petron Revx x400-800 diesel oils!
    Next time diretso na sa Petron car care center ang pms ko and revx oils na lang for my GS and MS. Dala na lang ako ng sarilin oil filter.
Mineral , semi synthetic or fully synthetic?
