Results 6,351 to 6,360 of 6542
May 13th, 2021 05:28 PM #6351
It takes longer than that for all of the used oil to come out. Compressed air helps accelerate things. It's still not perfect. If it were up to me, I'd leave it dripping through the night but this is obviously not possible when done at a shop, so compressed air is good enough.
And if you're worried about the compressed air contaminating the inside of the engine, rest easy that it won't matter. The by-products of combustion is filthier than outside compressed air can ever be. Also, the inside of the engine is turbulent and whatever trace residue that remained (water vapor, etc.) will be out of the PCV plumbing just a few seconds after the engine has started. All the rest will be burned off as the engine warms up.
May 13th, 2021 08:19 PM #6352
I see. I ordered the 4L and the seller took a photo and it is indeed API SP for the 4L.... Im satisfied with Xteer for now maybe will try another oil brand for my next oci.
May 16th, 2021 10:45 PM #6353
I am satisfied with the Xteer diesel 10w30 CI-4 oil for my 2014 Accent. My only regret is, because of this lockdown, I had to extend my o/c a bit longer than I had wanted & the summer weather is a bit too hot this year for the oil. Good thing Inhardly get stuck in traffic.
May 17th, 2021 07:59 AM #6355
May 24th, 2021 11:24 PM #6356
August 3rd, 2021 06:19 AM #6357
Mobil now has an official distributor in the Philippines
topgear writer doesn't even mention the lazmall. "Journalist" kuno
with the pricing of mobil, I'd rather go with Zic or Amsoil.
https://www.topgear.com.ph/news/indu...ef=home_feed_1
- Apr 2012
- 3,469
August 3rd, 2021 11:51 AM #6358Using Delo 400 MGX for my Grand Starex and Hiace
Shell HX5 for my vios.
Performs well so far
Sent from my SM-A507FN using Tapatalk
August 3rd, 2021 05:32 PM #6359
- Mar 2021
- 636
August 4th, 2021 01:23 AM #6360Just found out na at least CI-4 rating na pala ang Petron Revx x400-800 diesel oils!
Next time diretso na sa Petron car care center ang pms ko and revx oils na lang for my GS and MS. Dala na lang ako ng sarilin oil filter.
May nakita na naman akong ibang unit. Walang removavle cover but nung binutasab at binuksan, may...
2016/2017 Isuzu MU-X
