Page 636 of 655 FirstFirst ... 536586626632633634635636637638639640646 ... LastLast
Results 6,351 to 6,360 of 6542
    Jan 2009
    #6351
    when i change oil,
    i specifically specify, "gravity lang po. no flushing, no compressed air."
    it takes them 15-30 minutes to drain my engine.
    nagdadala lagi ako ng reading material.
    It takes longer than that for all of the used oil to come out. Compressed air helps accelerate things. It's still not perfect. If it were up to me, I'd leave it dripping through the night but this is obviously not possible when done at a shop, so compressed air is good enough.
    And if you're worried about the compressed air contaminating the inside of the engine, rest easy that it won't matter. The by-products of combustion is filthier than outside compressed air can ever be. Also, the inside of the engine is turbulent and whatever trace residue that remained (water vapor, etc.) will be out of the PCV plumbing just a few seconds after the engine has started. All the rest will be burned off as the engine warms up.
    Feb 2019
    #6352
    I have used the Xteer Ultra 5w30 on the ASX for two years now. Late last year I bought some to refill my stocks and the 6L containers already is API SP. The 4L container is still API SN.
    I see. I ordered the 4L and the seller took a photo and it is indeed API SP for the 4L.... Im satisfied with Xteer for now maybe will try another oil brand for my next oci.
    #6353
    I am satisfied with the Xteer diesel 10w30 CI-4 oil for my 2014 Accent. My only regret is, because of this lockdown, I had to extend my o/c a bit longer than I had wanted & the summer weather is a bit too hot this year for the oil. Good thing Inhardly get stuck in traffic.
    Aug 2012
    #6354
    anyone using amsoil diesel oil? how does it perform?
    thanks
    #6355
    Quote Originally Posted by soullinker20 View Post
    thanks
    We tried the Amsoil Diesel Euro formula for the Jetta TDI. Aside from the casa, only Amsoil we found to meet the oil requirements of the VW TDI engine. Oks naman.
    Aug 2012
    #6356
    thanks. excited to use mine sa 2012 strada. sinusulit ko lang casa oil before i change.
    #6357
    Mobil now has an official distributor in the Philippines
    topgear writer doesn't even mention the lazmall. "Journalist" kuno
    with the pricing of mobil, I'd rather go with Zic or Amsoil.
    https://www.topgear.com.ph/news/indu...ef=home_feed_1
    Apr 2012
    #6358
    Using Delo 400 MGX for my Grand Starex and Hiace
    Shell HX5 for my vios.
    Performs well so far
    Sent from my SM-A507FN using Tapatalk
    #6359
    Hx5 ftw. Its what I've been using. 4L jugs are dirt cheap lol.
    Mar 2021
    #6360
    Just found out na at least CI-4 rating na pala ang Petron Revx x400-800 diesel oils!
    Next time diretso na sa Petron car care center ang pms ko and revx oils na lang for my GS and MS. Dala na lang ako ng sarilin oil filter.
Mineral , semi synthetic or fully synthetic?
