here's the differences between cheap oil and mid-range oil. laki ng difference sa Noack volatility
but the repsol is probably "good enough"
btw: TBN is total base number. HTHS is hi temp hi shear
what's better? once a year oil change using P2000 (4 liters) oil. or twice a year with P1000 oil?![]()
As long as it meets the specifications set by the manufacturer, 2x using 1000 petot oil is my bet.. of course use 2x oil filter din
yeah that's what i was thinking also. coz there's plenty of stuff that the filter can't get rid of
ok na sana yang repsol neo but the HTHS is kinda low at 2.9 so it's optimized for fuel efficiency and not protection but that's ok for engines that are designed for lower hths oils i.e. those rated for acea a5/b5 oils
meron bang fake repsol oils?
I prefer every 6 months din..
madaya nga tong Honda.. tinanggal na yung regular oil tapos nagtaas pa ulit nang presyo.. dati 1200 lang yung regular oil nila..
Dapat semi ang inalis. Yan ang wala akong bilib. It's either mineral or fully synthetic.
Deceiving ung "semi-". Dapat synthetic blend.
Sent from my CPH1911 using Tsikot Forums mobile app
i haven't seen a user's manual that discriminates between synthetic and mineral
and let's not forget that "synthetic" is often just type-III which is actually mineral oilthe real synthetic oil is PAO
so to answer your question, semi synthetic is a mix of less refined mineral oil and more refined mineral oil![]()
Slightly OT, but couldn't resist sharing. Subie bought brand new from dealer, and was run 36,315km without a single oil change
https://www.youtube.com/watch?v=euHNdH-9zOM
Ano ba naman yung mga owner na ganito, basta tumatakbo lang its fine... tapos pag benta nakalagay pa, "Lady Driven!"![]()
got 2 jugs of this repsol for P2100, earned P390 cashback. just took it out for a spin, no weird noises. how bad can this oil be given the pricei'll be doing 6mo OCI w/ this oil. it's API SP rated
Bought a carton of Motorcraft full synthetic oils for around 4600. Sulit yun for 12 quarts! Good for 2 changes na eto sa XT.
