Delo din gamit Hino casa, delo at mobil oil ang highly recommended talaga sa heavy duty use, no choice lang kasi kami sa petron oils distributor kasi pakner ko ng petron oils, so far tested ko naman na yang petron oils, lalo na Yung hd40 nila na cheapest diesel oil, sa private use cars I use shelll r4x
Sent from my vivo 1906 using Tapatalk
pag ka recall ko sa manual ng hino is 20-25k oci using orig hino oil filters, i stick to 15-20k mas harsh naman kasi climate natin dito sa pinas compare sa japan, bro kahit delo 400 at shell r4x they advertised their oil can go up to 100k kms oci when they first launch their oil, di ko lang sure kung anong delo yun, delo mgx yata, pwede naman siguro yang 100k kms oci basta sa expressway lang byahe
This is what my oil looks like after 4,500km and 7months since my last oil change. The oil gets darker in color is this an indication that I need to have it replace? I use 15W40 Zic X7000 FS diesel.
The sure/best way to go is have a Used Oil Analysis.
You can go to the websites of SGS Phils or CRE Phils.
Sent from my CPH1911 using Tapatalk
the darkening of the oil is evidence that the oil is doing what it is designed to do.
i have seen worse (darker!).
mine.
my route is the congested ncr.
what is your route?
i wouldn't worry.
we replace oil + filter every 5000 km...
been doing it for 15 years now. engine still doing fine after 140K km.
Congested ncr also but morning no traffic only at night time heavy traffic 16km back and forth in a day. This is the first time that i tried using Zic X7000 fs diesel and was thinking if i could extend this further and just have the oil filter replaced.
Before I was using mineral oil and if mineral I follow religiously 6months or 5000km every oci. But for fs oil I tend to extend it further but upto what extent? I just use visual inspection if it gets more darker then for me it is time to have it change.
The last oil change I did with my 2KD was Dec '19. Since then, I've only clocked up around 2,500km because of the pandemic. However, I'm still replacing my oil this Dec, 12 months after the last one.
based ko sa photo ni deesstone. Pwede mo pa sagarin yan hangang 15,000kms. At 4,500kms eh malinis pa. Malayong-malayo pa sa totoong dumi ng desel.
Check the color at 8,000kms.
1904 kms pa lang tinakbo ng truck ko this year and i reckon i have to do the change oil routine once again before the 21st because by then it'll be a year old.
double filtration na baldwin oil filter gamit ko so mukhang ok pa naman pero a year old oil is a year old oil. although tempting pa mag extend![]()
