Page 251 of 330 FirstFirst ... 151201241247248249250251252253254255261301 ... LastLast
Results 5,001 to 5,020 of 6586
    Dec 2009
    #5001
    Well whatever the manufacturer or casa recommends, it doesnt preclude you from practicing due diligence by inspecting the status of the oil by lifting that oil dip stick
    A pitch black color for petrol engine is a telltale sign to replace the oil. That means the engine oil had gathered too much soot and prolonged use will be detrimental to your engine
    Additionally, a slow moving oil once the dip stick is inverted is a sign of oil thickness. Thick oil is less efficient in reducing friction and calls for replacement to the benefit of your engine
    Sent from my GT-P3110 using Tsikot Forums mobile app
    Jan 2009
    #5002
    I typically follow a 6-month PMS interval for my D4D Innova. I do 98% daily Metro Manila commute. And if you know MM at rush hour, it qualifies as 'extreme' conditions... bumper-to-bumper, stop-&-go traffic, long idle times, heat-soaked powertrain, dusty conditions from all the road works every several hundred meters, etc. Nothing about MM is 'normal' unless you only drive during the wee hours of the morning.
    I follow Toyota's recommendation of 1-yr OCI/ODI (fully-synthetic oil) and 6-mo oil filter change. With the EGR blocked, there's even less soot contaminating the engine oil so this works out as the best strategy for me.
    #5003
    doesn't EGR blocking promote pollution?
    Jan 2009
    #5004
    This is not the thread for it. I believe I already stated my opinion and reason in the appropriate thread.
    May 2017
    #5005
    Quote Originally Posted by igiwtf View Post
    whats the cheapest way to maintain an engine? in Petrol or Diesel engine?
    what particular brand do you use?
    synthetic? 10kms interval change oil
    semi / mineral? 5kms interval change oil
    Not all oils are the same
    but a simple basic rule.
    If its mineral then change at least every 5k, mineral breaks down quicker than a semi or fully synthetic oil.
    If its semi or fully Synthetic then anywhere from 7k to 10k.
    Ive been servicing and changing oil on all my cars from V8 to 4cylinders for the last 30yrs and the key is to always have clean oil in your engine never run it over the required oil change. I never use fully synthetic as it some cases it can cause glazing inside some engines (not all) either mineral or a semi synthetic ive been using. But if mineral I only use Delvac mx which is good for my 2016 Dmax as long as you change oil regular. But im Using a semi synthetic Multi-Z oil now from dealership as its still under warrantee, but once warrantee expires I will either use delvac or Delo 400.
    Ive never had any engine issues with any oil ive used provided its a known proven brand.
    The perfect oil change is 200hrs!, I used to work as a driller in mining and all there diesels they would change every 200hrs because most of the time was spend on running the engines not driving. This is true for vehicles today you spend alot of time at the stop lights idling and even though your vehicle is not moving your engine is still running.
    My Dmax has an hr engine running timer which goes on at engine start and goes off once engine is switched off. Once it hits 200hrs then the oil is changed even if the mileage is below the required amount. This is the best time to change the oil.
    I dont believe in long oil changes even is using fully synthetic because the longer you leave the oil the longer all the dirt stays there regardless of oil brand.
    Expensive oils do last longer but all oils will circulate dirt.
    The reason why so many car manufacturers push for long oil changes is to get approval of those environmental people, thus getting more approval and ex-poser to sell more cars.
    So no matter what oil you use the longer you leave it in your engine the longer the dirt will circulate inside your engine regardless if its Mobile 1 or just a simple mineral oil.
    Most OEM oil filters dont work as good at around 10k so if your a 10k oil changer guy then at least change your oil filter at halfway at 5k or get an after market oil filter thats better than the OEM one..
    Everyone has their own opinion on oils as you can see this post has been running for years! but this is what works for me.
    I dont use any engine chips, blocked EGR or Catch can and Ive never had any issues with carbon build up so far.
    One of the main causes for rapid carbon build up is not running engine on the HWY much, poor quality oil and cheap dirty fuel as well as not replacing fuel and air filters when needed.
    Yes carbon will build up but it should not be an issue until well over 100k then you either clean up the build up or replace EGR or what other parts is needed. This will only have to be done once in the life of your engine by this time you would have probably sold it.
    This was my 2cents worth
    God bless you All
    #5006
    i'm sorry.
    a simple yes or no, would have been more informative.
    not everyone is a whiz at searching thru tsikot.com .
    Feb 2014
    #5007
    some manufacturers say every 10K km ang change oil intervals for ordinary driving conditions.
    what they might not be saying, is that the oil filter must be replaced every 5K km.
    what's your take on this, guys?
    open your manual
    goto the maintenance section w/ the items "motor oil" and "oil filter"
    look at the interval for the oil filter. there's usually a dot
    simple isn't it
    Feb 2014
    #5008
    Ang masasabi ko lang, dito sa Pilipinas, considered severe driving conditions na tayo automatically..
    LOL. it's not about the country it's about DRIVING CONDITIONS! there are countries that are hotter, or w/ worse traffic than the PH city you're now in
    again, read the manual to be guided. SEVERE usually means repeated short trips (not enough time to get engine hot enough), idling a lot (i.e. engine turns/wears but ODO doesn't tick), etc
    Jan 2009
    #5009
    i'm sorry.
    Ok.
    The answer is yes and no.
    If you want the more elaborate answer, be a whiz kid. ;)
    Jan 2009
    #5010
    Let me just say that the operational term used in most manual is "OR". That said, if you encounter any of the said conditions under "Extreme", then you follow the maintenance schedule for it. You don't necessarily have to satisfy everything for it to be considered extreme.
    Mar 2004
    #5011
    i'm sorry.
    a simple yes or no, would have been more informative. not everyone is a whiz at searching thru tsikot.com .
    With regards to EGR blanking ... the answer is more complicated than a simple yes or no ...
    Mar 2004
    #5012
    Quote Originally Posted by Vodka View Post
    LOL. it's not about the country it's about DRIVING CONDITIONS! there are countries that are hotter, or w/ worse traffic than the PH city you're now in again, read the manual to be guided. SEVERE usually means repeated short trips (not enough time to get engine hot enough), idling a lot (i.e. engine turns/wears but ODO doesn't tick), etc
    Have read quite a few operating manuals of vehicles ... quite a few of them define severe driving conditions to include dusty and hot environments ... so the place you are driving in is also a factor in driving conditions ... also in this country, the weather is normally hot and does not fluctuate too much between hot and cold so engine oil, lubricants, etc takes lesser time to get to optimal temperature ...
    Metro Manila and major cities in this country could be classified as severe driving condition areas ... while some provinces with less dust and traffic would be better ...
    Dec 2009
    #5013
    When an engine begins to burn fuel it will be much hotter than the extreme ambient temperature a tropical climate can produce
    Mar 2005
    #5014
    Share lang.. Maintennce under Severe conditions from the Owners Manual of my Santa Fe 2.2 Diesel . Yung highlighted in red is yung driving conditions ko na na eencounter.
    Jan 2009
    #5015
    True, but in cold weather, heat is dissipated much more quickly and there's less chance of engine hotspots to develop.
    May 2017
    #5016
    Kv7iilcccc
    Sent from my SM-J510GN using Tsikot Forums mobile app
    Jul 2017
    #5017
    Sir maganda po ba ardeca? Saan po kayo nagoorder? Thanks
    Quote Originally Posted by fireice2 View Post
    Happy ako sa Ardeca. 5w-40 CJ-4 at 250+/L
    Sent from my MI 5 using Tapatalk
    Apr 2014
    #5018
    Quote Originally Posted by gepot17 View Post
    Opo bossing. Great value talaga. Hindi masakit sa bulsa.
    this company expanded most probably because of the lower market oil price. they can sell at an unbelievably low price.
    ardeca belgium also started selling in my area...
    Apr 2014
    #5020
    They have the necessary certifications. I'm happy with that.
    Just waiting for the local distributor to bring in the Pro-Tec Ultra 5w - 30. Para magamit ko sa diesel at gas cars ko. Sa ngayon 5w - 40 lang ang pinapasok dito
Mineral , semi synthetic or fully synthetic?
