Page 261 of 330 FirstFirst ... 161211251257258259260261262263264265271311 ... LastLast
Results 5,201 to 5,220 of 6586
    Aug 2012
    #5201
    grp3+
    I'm thinking if mag-HX7 na lang. Change oil every 12 months.
    Sent from my ASUS_X00DDA using Tapatalk
    which vehicle? oil capacity?
    Oct 2005
    #5203
    any feedback sa Shell hx7 5w-40? gagamitin ko para sa Honda jazz 2009 39k mileage. Currently gamit ko ngayon Honda Vtec lev Fully Syn 5w-40. mas mura kasi sa shell kaya gusto ko try.. Thanks
    Feb 2014
    #5204
    Quote Originally Posted by toast View Post
    mura hanap mo? i have a honda city w/ 140,000 kms. i've used the same honda (idemitsu) mineral oil since day 1. i didn't bother to use anything else
    up to now it doesn't burn oil. wala din usok. runs smooth. i have absolutely no reason to spend more on fully-synthetic
    its good.. but far from fs oils. that vtec fs will last longer..
    #5206
    mobil1 new life 0w40
    best oil in the business. even ceratec cant improve it🤣. found a supplier 6000/12liters. imported from france
    ceratec works on less capable oils...
    Ceratec Liqui Moly How well the oil additive protect the engine? 100
    Can i get a lead sir? Interested with the mobil
    Quote Originally Posted by timykoo View Post
    european market area ako...
    locally look for dexos1 or acea a5b5. very good protection for gas applications.
    Dec 2013
    #5208
    Nearing 130,000 km na si monty. Due for change oil na naman. Last oil used was mobil delvac mx 15w-40 + bd28 combo. Naisipan ko tingnan specs ni Delo 400 MGX at naicompare sa Delo 400 multigrade, mas mataas pala TBN at SAPS ni Delo 400 multigrade. Higher means better?
    Quote Originally Posted by Geronimo Valino View Post
    higher tbn yes
    low saps benefits the dpf... but your vehicle probably doesnt have a dpf.
    12×1liter 3000pesos equivalent
    good for everest and rangers 😁
    Jul 2016
    #5211
    May naka try na ba ng shell r4x any comment? Mura kasi 200 lang ata per liter.
    Sent from my vivo 1606 using Tapatalk
    Aug 2013
    #5212
    galing akong Mobil Delvac MX (10k to 40k kms) to Shell R4X (45k to present, currently at 70k kms), wala masyadong pagkakaiba.
    sa shell station ako bumibili ng oil, P197/L.
    every 5k kms o 6months ako nagpapa change oil.
    Jul 2015
    #5213
    im using gulf ultrasynth x 5w30 right now, coming from royal purple 5w30, it seems ok naman..
    Jul 2016
    #5214
    Quote Originally Posted by innova2013 View Post
    Thanka sa info sir
    Apr 2012
    #5215
    Yan gamit ko sa Hiace at H100 namin. Oks na oks naman. From Delo Gold to R4X. Nasa 1200 lang for 6 litres
    Sent from my SM-J730G using Tapatalk
    Dec 2013
    #5216
    higher tbn yes
    Thanks pards. Will alternately use both oil. High tbn and saps means better engine protection for my ride considering it has no dpf.
    Dec 2017
    #5217
    Currently using PTT 0w-20 from Lazada. Kia Rio 08 model.
    Quote Originally Posted by daryldeal View Post
    good fc ang rio?
    Apr 2012
    #5219
    ok yan, mura na 200/li. ilang kms bago ka magpalit?
    Apr 2012
    #5220
    5k kms pa din. Hehe pang byahe kasi si Hiace. So 2-3 months change oil na [emoji16]
Mineral , semi synthetic or fully synthetic?
