Page 254 of 330 FirstFirst ... 154204244250251252253254255256257258264304 ... LastLast
Results 5,061 to 5,080 of 6586
    Dec 2013
    #5061
    Quote Originally Posted by max 122 View Post
    Please try ardeca lubricants we have sx 5w30 sn na api nya. best for gasoline fully synthetic 210 per liter lang made in belgium. For diesel naman fully synthetic protec ultra 5w40 cj-4 na api rating nya. We have manila in davao.
    Sent from my SM-J700H using Tsikot Forums mobile app
    Eto ba yung enoc protect ultra 5w-40? Saan sa manila store?
    Quote Originally Posted by Geronimo Valino View Post
    enoc is another brand. iba ang ardeca
    Aug 2017
    #5063
    Ardeca po ito sir enoc is from malaysia ardeca from belgium. Po sa makati po magallanes commercial center po.
    Aug 2017
    #5064
    Thank you. Ardeca lubricants will cover all in the philippines.
    Aug 2017
    #5065
    Quote Originally Posted by fireice2 View Post
    They have the necessary certifications. I'm happy with that.
    Just waiting for the local distributor to bring in the Pro-Tec Ultra 5w - 30. Para magamit ko sa diesel at gas cars ko. Sa ngayon 5w - 40 lang ang pinapasok dito
    Sent from my MI 5 using Tapatalk
    Nag parating ako pro-tec ultra 10w30 sir. Pero 5w30 sir sa diesel medyo manipis kasi kaya recomment namin mataas vescocity sa clima natin sa pilipinas.
    Aug 2017
    #5066
    Quote Originally Posted by gepot17 View Post
    Sir maganda po ba ardeca? Saan po kayo nagoorder? Thanks
    Let me know if gusto nyo po. Kami po distributor sa pilipinas sir ng ardeca.
    Aug 2017
    #5067
    09988456800
    Apr 2010
    #5068
    Pwede na pala selling harap-harapan sa forum?
    Aug 2012
    #5069
    Any feedback on PTT Performa Super Synthetic SAE 0W-40 gas engine oil? 4L bottle is P1,900.
    Sent from my ASUS_X00DDA using Tapatalk
    Wow 0W40 most likely a grp3 and grp4 base oil. Does it have BMW LL01 approval? It would still be ACEA A3/B4 I would assume, which is good for extended oil drain intervals.
    Aug 2012
    #5071
    API SN, ILSAC GF-4, ACEA A3/ B3, MB 229.1 (SAE 0W-40)
    PTT Philippines Corporation - Products and Services
    Apr 2014
    #5072
    Kaso Semi-Syn lang yung pro-tec ultra 10w-30
    Quote Originally Posted by red_one View Post
    its API-SN lng pala and MB229.1(this is an old old MB approval).
    Mitasu MJ-112 is better than this. I think its 200 pesos more? I'm not sure.
    SPECIFICATIONS / APPROVALS
    ∙ API SN/CF
    ∙ ACEA C3-10
    ∙ ACEA A3/B3-08
    ∙ ACEA A3/B4-08
    ∙ GM dexos 2
    ∙ PORSCHE A40
    ∙ BMW Longlife-04
    ∙ MB Approval 229.31
    ∙ MB Approval 229.51
    ∙ RENAULT RN0700/RN0710
    ∙ FIAT 9.55535-S2
    ∙ FORD WSS-M2C-917-A
    ∙ VW 502.00/505.00/505.01
    Oct 2004
    #5074
    Redline oils? I have heard good reviews pero all from abroad. Meron kayang supplier ng redline oils dito sa atin?
    Meron... Matagal ko nang gamit Redline oils (kaso sa gasoline engines, di ko pa nasubukan on diesel engines). I like 'em better than Motul (H-tec lang, can't afford 300V, hehe).
    AFAIK, lahat ng Redline engine lube oils ay Group V.
    I buy Redline oils sa Autotech (#2000 Singalong, Manila)... In between Quirino Ave. and San Andres. Try to give them a visit or call 02-4043594.
    #5075
    Quote Originally Posted by EssB View Post
    Thanks Sir! Will try them one of this days.
    mobil1 new life 0w40
    best oil in the business. even ceratec cant improve it🤣. found a supplier 6000/12liters. imported from france
    ceratec works on less capable oils...
    Ceratec Liqui Moly How well the oil additive protect the engine? 100
    Jan 2009
    #5077
    I've read in many literature and videos that the 'one-armed bandit' test is irrelevant on engines. It is said that even the Head & Shoulders shampoo, due to its high zinc content, would easily pass the test. This is to say that there's more than one testing standard for motor oils and oils passing the one-armed bandit test does not signify it will perform well in all other, more relevant tests.
    #5078
    ang nagpa-popular nang one armed bandit tester na yan dito, ay si per'tua.
    my question is, what happens when high metal temperature and high pressure come into the equation?
    i wonder...
    how does mane n tail do in that test?
    #5079
    Bro anong complete specs ng Redline oils, at magkano?
    Ang lapit ko lang dito.
    Oct 2004
    #5080
    Ang alam kong usual na available sa Autotech ay 5W-30/5W40/5W-50/10W-30/10W-40/15w-40(CJ-4). P600/quart last na bili ko (baka nagtaas na ulit).
    Meron ring mga gear oils (even for LSDs)...
    Red Line Synthetic Oil - Motor Oil
    Red Line Synthetic Oil - Technical Files
Mineral , semi synthetic or fully synthetic?
