Page 76 of 330 FirstFirst ... 266672737475767778798086126176 ... LastLast
Results 1,501 to 1,520 of 6586
    #1501
    well that sucks. hehe
    i was looking forward pa naman to using a bonafide true blue full synthertic lubricant when i bought those. i guess it's back to mobil 1 for me
    btw, how about those valvoline 5w-30s? at the very least, group IV na ba iyong mga iyon?
    http://www.valvoline.com/faqs/motor-...tic-motor-oil/
    What group of base oils is used in the formulation of SynPower?
    Valvoline uses a mixture of Group III and Group IV basestocks.
    Dec 2009
    #1502
    meh nakasubok na ba dito ng shell rotella personally? either the triple protection or the rotella 5w40...
    meron kasi ako nakita sa sulit nag paparating from states ata....
    Quote Originally Posted by miko101130 View Post
    Highly rated yan bro sa states. kahit sa mga motor with wet clutches patok na patok yan dahil maganda daw talaga performance. Mas popular pa nga sa Mobil1 TDT 5w40 eh afaik. Yung Shell R3X 15w40 yan naman katapat nang triple protection. How much yung Rotella T6? Yun yung maganda reviews eh.
    May 2010
    #1504
    Need suggestion po:
    Im for due oil change *45k pms.
    Would be doing it outside the casa na lang, most probably to my suking gas station.
    Nag backread na ko for mineral oil vs fully synthetic.. Mejo torn pa din in between kase sabi nyo dito for mineral oil every 5k km ang change oil + filter.. Pag fully synthetic, every 10k km or per year..
    Sa situation ko po, im just averaging 5-7k km per year... Should i go mineral or fully synthetic?
    Leaning towards caltex oils kase baka dun na din kase pachange oil..
    Oct 2011
    #1505
    depends on your budget sir. if you are willing to go with FS oil then go ahead change oil yearly or every six(6) months using mineral oil since you have a low mileage.
    May 2010
    #1506
    Sorry for the noob question. For mineral oil ba, is it a "must" to change oil every 6months even if less than 5k km?
    Btw, pajero fm po ride ko.. baka kasama sa analysis ang diesel va gas.. Thanks!
    #1507
    Quote Originally Posted by romeocharlie View Post
    You can extend naman beyond 6 months. Pero try to monitor parin yung mileage, oil level, and fuel efficiency. AND kung sa 5k na tinakbo e most of the time ba nasa traffic. I doesn't show up kasi sa odometer.
    Need suggestion po:
    Can't go wrong naman with either, as long as you follow the recommended oil change intervals. If you feel that what you've used for the first 45k is fine, stick with it. Kung namamahalan ka, try using mineral pero with a quality filter parin to keep the oil clean.
    Think of conventional and synthetics as a hammer and a rock, both can drive a nail down a piece of wood.
    Oct 2011
    #1508
    Advisable sir lalo na diesel ang engine. Kahit nga ung FS oil, ung iba hangan 7k oil change na.
    May 2010
    #1509
    Mas maganda ba sundin yung 5,000km rule? Kesa i-based sa months 3,6 or 12mos? Kase weekend ko lang nagagamit, then bahay-church-mall lang mga 5-7kms lang yun i think..
    So baka nga yung 6 months ko less than 5,000km, eh what if mineral oil lang pinalagay ko? Lets say 3,000 pa lang in 6months? Change oil na din?
    Thanks.
    #1510
    Thanks.
    Mahirap sagutin yan kasi we all have different opinions. Pero kung nasa warranty pa, stick with the recommended oil change interval. May mga casa naman na mabait na pwede yung kilometer reading yung basis, wag lang sobra sobra na once a year lang pinapa service kasi mababa ang mileage na tinatakbo.
    Apr 2011
    #1511
    Pansin ko lang puro multigrade na mga oils na binebenta. Wala na akong nakikitang monograde oil. San kaya makakabili pa ng monograde na oil
    Sent from my GT-N7000 using Tapatalk 2
    #1512
    Thanks.
    5k ang conventional na basehan, plus or minus pa rin yan kumporme sa sitwasyon. Laging traffic, dusty yung area, rugged road... (yan ang mga nakakapagpababa ng km para mag change oil ng 5K-PMS (mineral oil), to determine dapat matutunan mong mag base sa kulay at hipo ng langis sa dipstick.
    Usually pag maitim hanggang sa maitim na maitim ay dapat ng paliitan yung langis. Sa hipo, labnaw at lapot lang ang basehan.
    May 2010
    #1513
    Quote Originally Posted by nivraarvin View Post
    Wala na sa warranty.. Nakasanayan kase namin na every 5k ang checkup sa casa nun, regardless kung umabot ng 6mos or 1year.. Naka fully synthetic naman kame nun.. Pero last na napalagay early this year eh mineral oil lang.. Medyo naghihigpit ng sinturon ngayon kaya sa labas ako ngayon magpapachange-oil.. Kaya ang dilemma ko eh if magmineral muna ulit, sabi sa pms manual naman eh light checkup lang sa casa and change oil lang gagawin.. Then come 50k, should i go back to casa and balik fully synthetic, Para di rin malito sa bilang.. Parang every 10,000 ako nun change oil, then every 5,000 palit filter at top up lang.. Tama nga ba?
    #1514
    If your oil will last 10k, you still need to check other things at 5k. If you can DIY that, then mas makaka tipid ka.
    Visually inspecting the color of the oil is not a good basis(of oil life left). If your oil has low detergents, it may look clearer than an oil with higher detergent levels. That means the oil that is "blacker" actually dissolved more deposits in the engine, making the inside of the engine cleaner.
    I have a friend who is a mineral oil user since day 1. I convinced him to switch to synthetic, after 1 year, he changed his oil and saw that the oil is black and there are some gelatin like oil coming out. He thought panget ang synthetic oil. He switched back to mineral, not knowing that the synthetic oil actually dissolved oil sludge from his engine.
    May 2010
    #1515
    Quote Originally Posted by Noel Salisipan View Post
    In terms of traffic, wala.. Usually 5-10 mins ride lang from house to mall or church.. Usually yun lang trips ko..
    Oct 2011
    #1516
    Quote Originally Posted by jay185 View Post
    meron sa ace hardware mmonograde.
    Apr 2011
    #1517
    Went to ace hardware and saw one. Pero magakasing price lang sila ng multigrade. Kala ko mas mura sya ng di hamak. Gagamitin ko lang sanang pang flush ng engine.
    Oct 2011
    #1518
    mahal talaga price ng ace sir. eh mobil brand pa ung mga monograde nila.
    Aug 2006
    #1519
    Mga paps, what is the general rule of using engine flush products?
    Im on my 20k pms and planning to change brand of gas engine oil. Do I need to purchase engine flush if I change oil brand or if i change from synthetic to mineral or just simply everytime you change oil kahit same brand?
    Appreciate your expert opinion. TIA.
    #1520
    Quote Originally Posted by jigs_xix View Post
    You don't need it unless your engine is dirty or have oil sludge. Though I see Mitsubishi recommending it all the time. I personally don't use it.
    Find an oil that works for you and stick with it. I don't see a reason why to change oil brands all the time, unless the reason is about budget.
Mineral , semi synthetic or fully synthetic?
