Page 176 of 200 FirstFirst ... 76126166172173174175176177178179180186 ... LastLast
Results 3,501 to 3,520 of 6586
    Dec 2009
    a 10w30 degrades to a thinner weight ... once it shears to ultra low visco... hths falls to less than 2.. film strength goes to a cliff of no return [emoji28]
    do you mean used oil gets thinner by gathering soot from fuel combustion?
    gathering soot cause oil to thicken
    Sent from my ASUS Chromebook C202SA using Tapatalk
    Jan 2009
    Don't confuse oil viscosity with oil that's in its early stages of becoming sludge.
    or subpar soot filtration ?
    bro not all engines are the same. your oil filter alone is 3x-5x bigger than mine. this together with the 7L enables extended oci. why 5000km oci though? i think youre doing 150km per day. how many hours for the round trip drive?
    Feb 2015
    150kms and approx 3hours per day, divided into 2 drives (one in the morning and one in the afternoon).
    Maybe around 50/50 hi-way and provincial driving.
    I have no science-based reason for my 5000km oci. I just think that its "safest" to assume that my car goes through severe driving conditions here in the Philippines. But of course at the expense of my wallet.
    I would like to be persuaded to do extended oci though.
    Now, I am looking at some ways on how I can lessen my "daily" car expenses(fuel, engine oil, PMS) to give way to the replacement of other parts like tires, brake pads, etc.
    Quote Originally Posted by makelovenotwar View Post
    I dont think you fall under severe conditions.
    1. youre not idling too long.
    2. were using euro4 fuels. euro2 diesels required shorter intervals
    3. youre doing mostly highway
    youre oci is too premature. 5000km at 2mo is only 133hrs of oil use(removing weekends 44days)
    you can easily double your oci.. even 3x
    Feb 2015
    wow 2x or 3x! Thanks bro!
    I will definitely consider this and start plotting my PMS schedules and budget!
    use api- cj4 bro... better additives
    bro bundok ba lugar nyo? baka puro harurot hehehhe
    Feb 2015
    Hindi bro, patag naman.
    "Normal" driver lang ako. Bihira nga mag-more than 2k rpm eh. Kapag lang umo-overtake lang sa mga tricycle at jeep sa probinsya. Sa SLEX naman ay 80-100 kph lang. Parang nasa 1.8k rpm yata yung 100kph.
    12.5 - 13.5 kms / liter ang usual na fuel consumption sa route ko computed using full tank method.
    ayos tatagal talaga oil sayo.
    sakin frequent 4k 5k rpm [emoji28] bundok kasi..
    im shearing oil fast [emoji28][emoji28][emoji28]
    Feb 2015
    thanks sa info!
    Dec 2013
    thanks sa info!
    Wrong quote. Kay stock engine extreme driving conditions. Naabot ko lang 4K rpm sa monty kapag italian tune-up. 500kms weekly drive naman ako. Stick to less costly 5k oci with mineral engine oil.
    Dec 2017
    May I know where is that mountainous place? You must have fun driving that area!
    its a 10min drive uphill. elevation: 10-2200mASL
    karamihan mabagal takot sa 4000+ rpm [emoji28] marami din tumitirik [emoji28][emoji28][emoji28]
    nasa ibang bansa ako bro.
    meters above sea level hehehhe
    ibang asl yan bro! lol
    Jan 2009
    ASL and AGL are above sea level and above ground level, respectively. ASL is seldom used in ham radio. Most antenna height measurements are typically measured AGL.
    In chat parlance during the days of ICQ and IRC, ASL means age, sƏx (gender), and location. It can be used as a question or an answer; ie. ASL? or 26/M/Baguio.
    Dec 2017
    Interesting! And there were call signs starting with DU3 or something. I never had a license so I don't know what that means. I think ASL is "colloquial" or it was just starting to be used back then, just like "rain dancing" meaning taking a shower. I really don't know, I mean, I just remember these things...
    So, you are 26 and a male from Baguio. I'm a bit younger, 24.
    [emoji3]
    Jan 2009
    [emoji3]
    Nope. Not my ASL. That's just an example... I'm way older.
    DU is class A
    DV is class B
    DW is class C
    DY is class D
    DX is a permanent base station
    The number after that pertains to the district the callsign is registered to. It's from 1 - 9, so DU1 is a class A amateur radio operator registered in NCR.
    Philippine Amateur Radio Association (PARA), Inc.
    BTT:
    Anybody else doing a mid-stream oil filter change on their Diesel engines?
Mineral , semi synthetic or fully synthetic?
