Is this any good? Api sn siya.
ok nga ba ang mitasu? gusto ko din try ito para sa fd namin : MJ-112. MITASU MOTOR OIL SM 5W-40 100% Synthetic - MITASU OIL CORPORATION, JAPAN
mukhang ok naman specs niya eh
Good pm sirs
Where can I find Torco and Silkolene distributor or seller here in Manila? I tried the posted phone numbers online pero none of them are working. Thanks!
I'm kinda confused. According to my Vehicle's Manual for Grand Starex.
API CH-4/ACEA A3/B4.
May mga oil ako nakikita API SN lang pero may ACEA A3/B4. Pwede rin ba yun sa Grand Starex ko?
Ok naman yung price nung mitasu. Just need to research some more on it. Hehe mas mura sa royal purple hahaha
pwede yan..
CH-4 (1998 Reduced Emission Diesel Engine Service) = The CH-4 category is intended to address the requirements for high-speed, four stroke diesel engines to meet 1998 exhaust emission standards. CH-4 oils are specifically compounded for use with diesel fuels containing up to 0.5% sulfur. They can also be used in gasoline engines when combined with the appropriate “S” category when the vehicle or engine manufacturer recommends.API CH-4/ACEA A3/B4
ACEA A3/B4 = Stable, stay-in-grade oil intended for use in high performance gasoline and direct injection diesel engines, but also suitable for applications described under A3/B3.
Ibig sabihin pwede mo gamitin sa gasoline engine. (Kung ang kotse eh pwede SL pa rating eh mas maganda gumamit ng ci-4/SL. Pero kung minimum rating sa car user manual ay SM or SN na eh ang maganda gamitin SN/ILSAC GF-5)
Ang ACEA eh sa europe, counterpart ng API.
Yung motul crdi specific incomplete yung label sa likod. Pag sa diesel hindi ako gagamit nyan. Hanap ka ng CI-4 rating.
Saan kaya pwede magpa oil analysis? I used 5w20 on my 4b11. Gusto ko sana makita kung anong effect. Mostly concerned on wear metals. Thanks.
Posted via Tsikot Mobile App
^baka pwede pa dito..
http://tsikot.com/forums/other-troub...sis-lab-14481/Monark (Cat dealer) offers used oil analysis at affordable rates. They call it their SOS- scheduled oil sampling- available in their lab facility in Libis, QC. Contact Cris Salvador at tel- 637 9521.
SOS analysis charge:
1) complete testing: Php605 (sos-comp)
wear metals, total base number for engine samples, viscosity either v40 or v100, flash point, water by distillation.
2) complete testing: Php770 (sos-wopc)
same as above with particle count
3) normal testing: Php385 (sos-basc)
wear metals, fuel dilution, water by hotplate
Volume of sample required:
complete test- 250ml
normal test- 100ml
Haven't tried it yet but heard their results are reliable.
Suggest we share test results on this forum, specially on new oil tests, so we have benchmarks for our used oil tests.
SCHEDULED OIL SAMPLING
Did you know that the oil in your engines and machines oftentimes tell you the condition of your unit?
S-O-S analysis helps you by identifying and measuring various contaminants and sources of oil breakdown, thus helps prevent excessive wear and eventual failure of your machine.
With S-O-S, you can:
Detect problems early so they can be repaired before they become major failures.
Monitors positives and negatives, so you won't pay for repair of components that are not broken.
Schedule downtime that fits into your workload.
Monitor maintenance schedules and better manage budgets.
Develop complete profile and history of each piece of equipment, keeping your equipment with high resale value.
For inquiries, please contact:
(02) 634 - 0428 or 635 0901 loc. 1271 or email us at customercare*monark-cat.com
Scheduled Oil Sampling
Sk lube makers of Zic oil sponsor pala sa incheon. Malaki company pala talaga sila
^ nice... First timer using Zic oil so far so good (Zic Rv & A)
