I believe it's the other way around. Engine knock due to pre-detonation is more likely to occur if the AFR is too lean.
TS:
Is it really a hard knock or more like a tick?
My take on this is that the oil, which hasn't reached operating temp yet, is still inefficient at doing its job immediately after a cold start. The noise should eventually dissipate as the engine warms up. If not, then you have a problem.
