Page 52 of 93 FirstFirst ... 24248495051525354555662 ... LastLast
Results 1,021 to 1,040 of 1853
    Dec 2007
    #1021
    Quote Originally Posted by radiator3L View Post
    Glad to read all the positive results from your testimonies Sirs... Will surely pass the emission test by the LTO and ASBU
    at all times. All PUBs, PUJs, PUVs, AUVs, and Trucks must practice this system to minimize heavy smoke, smog, and air
    pollution in our environment. And respiratory problem as well.
    It must be emphasized that this practice may only reap its benefits if PROPER MAINTENANCE is executed. Sadly, this is not the case for most PUJ owners as well as some PUB, PUV, AUV and Truck owners.
    Aug 2008
    #1022
    Quote Originally Posted by timo07 View Post
    I certainly agree. 2t is not the magic solution to smoke belching. It must be coupled with proper maintenance...
    Jan 2010
    #1023
    ^ Bro CB, I advice against using Petron oils, wala kasi MSDS data mga yan, mahirap na. Baka sobrang low quality ng 2T nila. Shell or Caltex na lang, maliit lang naman difference for sure. hehe
    Just a thought though.
    sir bring out ko lang ito, i bought petron 2T premium kasi...
    totoo ito sir?...
    Quote Originally Posted by nvidi.turion View Post
    totoo ito sir?...
    Sa 2T sir no problem yan at least. Pero it has been shown here na maganda din yung petron all-terrain synthetic oil BTW. Medyo old post ko na yan eh, may update na. Mukhang hindi na lang kumuha petron ng API rating kasi nga mahal.
    Apr 2011
    #1025
    Passed by shell and ang meron lang sila is Jaso FB na 2t decarbonizer. Yun lang daw ang 2t ng shell 129pesos yung 1liter. Will look later at caltex
    Sent from my GT-N7000 using Tapatalk 2
    Quote Originally Posted by jay185 View Post
    Yan gamit ko.
    Apr 2011
    #1027
    Caltex 1L havoline 160esos
    Jul 2010
    #1028
    Usually 25php/200ml
    1L = 100php
    What you want is the cheapest oil as per devildoc said
    Apr 2011
    #1029
    Btw. Where can I source out fleetguard filter for my Navara. Meron ba sa Banawe?
    Jan 2011
    #1030
    the filter guy is here in the forum. he runs the filter depot.
    Apr 2011
    #1031
    Quote Originally Posted by shelu View Post
    What's his handle?
    Jun 2010
    #1032
    What's his handle?
    dvldoc and bayen
    #1033
    Jay, no much good filter for our navara from FG not unless you do bypass or re-fit fuel lines with spin-on adapters.
    Pls check Navara forum, i've compared all the filters and settled for OE fuel & Baldwin for lube. Anything longer than B233 will hit coolant pipes.
    Jan 2010
    #1034
    thanks sir...
    Apr 2011
    #1035
    Thanks Bro. So no choice pala hahaha. I get my filters from crvi Pasong Tamo.
    Apr 2011
    #1036
    nag start na ako gumamit ng shell 2t kanina, filled my navara with phoenix's diesel (aircon kasi cr kaya dito ako ang pa full tank) 70L kinarga, filled 400ml 2t since 80L talaga yung total capacity ng tank. wala pa namang noticable changes. ran 50+km na since full tank. first time ko ren mag karge with phoenix. caltex talaga ako simulat sapul.
    Apr 2011
    #1037
    Btw guys. Where do you get castrol activ 2t? Wala akong makitang ganito kahit don pa sa mga me banner ng castrol na shops.
    Nov 2004
    #1038
    After using shell with decarbonizer, seaoil, and petron 2Ts
    Nag settle ako sa Petron Powerburn yung dilaw, got best results with it.
    Mas noticeable yung less vibration, kinis manakbo at less nginig on engine off. At kahit malapit na sa 1/4 fuel gauge ko same pa din pino makina, sa iba kasi napansin ko pag pa 1/4 na gauge medyo nabawasan positive results.
    More than a year 2T user, pajero fm.
    Nasubukan ko na din dati, from manila to subic petron turbo diesel without 2T, putek ang gaspang (nasanay na siguro kasi ko sa 2T results)
    Pauwi nagkarga ko sa petron sbma diesel max lang plus 2T, hanep talaga nagagawa ng 2T, noticeable linakas hatak at kinis eh, parang gasolina manakbo at pansin ko mas tipid konsumo.
    Apr 2011
    #1039
    susubukan ko yang petron once ubos na tong 1L kong shell 2t
    Dec 2012
    #1040
    You oil level will be higher after letting the vehicle sit, it's called drain down time. You have oil in the heads and the rest of the engine that settles back down into the crank case. There is also a slight difference between hot and cold. Also remember the 2T is being burned during combustion and it's only 1:200 the of the fuel. It's not going to make your oil level rise nor will it dilute your oil. A non functioning anti drain back valve can cause this, The bad thing about this is your starting you engine dry when this is happening causing tons of engine wear. Start up noise will be a indicator of this.
    The 2t oil will also keep diesels of smoking as much. The orifice on a injector nozzle very tiny it will not really leak when not under pressure from the injector pump unless they are physically damaged or the orifice is worn out and you will get a big white puff of smoke on start up.
    Change your oil filter then check the oil level in the same condition , if you check it hot check it again hot, if you check it cold check it again cold and see what the level is.
    2T keeps the injectors performing correctly so they do not get clogged and have issues with tip damage.
    hi doc, i have try using petron 2t oil 200ml for 40liter diesel and i notice white smoke alot than before without 2t oil..it's not bold white smoke.. but you can see it's there.. can you give me advice,, thx
Diesel owners that add 2T oil to fuel
