Good day! I might be the last but not the least... I have tried using 2T on my Hyundai Santa Fe 2010 last week and the result is really very stunning! Engine noise, smoke, and vibration are noticeably reduced. Amazing indeed. Great result on my Toyota Hi-Lux too... FC and quick acceleration in effect. Flying-V + Shell 2T with decarbonizer at first try using the recommended ratio. Petron Dmax + Petron 2T Autolube at the present. And getting better... Compatible and more boost with my Hi-Lux equipped with Racing Chip and DevilsOwn Alcohol-injection system. Thank you so much DVLDOC...
After reading the entire thread
Gusto q din try to' sa gen. set and sa suzuki mini truck muna di q pa makumbinsi si pa eh! sakto sana sa old school engine sportivo nya!
1,800 bar = 26,106 psi
SKBR Auto (P) Ltd
Santa Fe - Hyundai Indonesia - New Thinking. New Possibilities
It is recommended to use 2T with JASO FC standard/rating which is SAE 20 compared to JASO FB which is SAE 30.
For Hyundai Santa Fe 2010 ( 194 HP ), 400 : 1 ratio will do to be safe. PTT Hi-Speed 2T, UniOil 2T, and also Castrol Activ 2T. These are the best source of JASO FC.
JASO FC SAE 20 2T is not that viscous ( thick and sticky ) compared to JASO FB which is SAE 30..
For non-high rail pressures and super advanced piezoelectric injectors :
200 : 1
200L = 1000mL
100L = 500mL
90L = 450mL
80L = 400mL
70L = 350mL
60L = 300mL
50L = 250mL
40L = 200mL
30L = 150mL
20L = 100mL
10L = 50mL
200 : 1
200L = 1000mL
100L = 500mL
90L = 450mL
80L = 400mL
70L = 350mL
60L = 300mL
50L = 250mL
40L = 200mL
30L = 150mL
20L = 100mL
10L = 50mL
Sir na test q na sa suzuki mini truck at pumino nga ang idle nya pero pag aarangkada pag bagong start hirap kelangan rebolution muna' kahit bagong patay lang ng makina
sobra ata ratio q
100 ml per 500 pesos ng gasolina
Ask ko narin kung safe rin sa 2013
Hilux 3.0 thanks
Safe yan.. D4D 2.5 vnt 2T user.. Minsan sobra sobra pa nilalagay ko.. No bad effects naman
