Quote Originally Posted by nitram View Post
Good day SIr Jake, Need your help on how to fix fuel leak on my Montero Sport injector.Leak comes out from the top portion of valve where the injector located. Somebody check and advice me replace the injector seal.Please advice where can I get spare part for this.Do advice also if you can fix at your shop(Central).Many thanks.
This is not a common problem. Has anyone previously worked on your engine? Yes this can be repaired at Central. Gaskets and/or seals will have to be purchased from Mitsubishi....
