How much for fuel injection calibration?
sir dieseldude, hingi lang sana nang advise. nabili ko yung sportivo ko 4 years ago. i really intended to keep it forever na sana, kaso na ondoy. mabuti na lang covered nang insurance. essentially pinalitan naman sa kasa lahat yung na damage gaya nang wiper motors (F&R), battery, lahat nang fluids, power windows/doorlocks, dashboard, stereo system clutch assembly. ipina full rustproof (interior/exterior) ko na din sa kasa.
its been a year since kinuha ko yung sportivo and so far wala naman akong nakikitang diperensya kaya lang kabado pa din ako na baka may lumabas na sira later on specially sa fuel injection/engine. do you think sir, this car is worth keeping even if na ondoy?
salamat po!![]()
Hindi ko naman nalita ang car mo, so wala akong masasabi.
Wala naman nasisira sa fuel injection system dahil hindi naman yan papasukin ng tubig baha....................pwera lang kung pinaandar mo nang hindi ka pa nag drain ng fuel tank.
Kung 1 year na yan tumatakbo after ondoy, okay na yan. Wala din madaming electronics ang Sportivo.......
So don't worry.
salamat po!You're welcome....
I just changed my fuel filter and now FC is worse. Used to get 10-11Km/L highways and now it's just 9Km/L. Weird...
It a 4D56 on a 2006 Adventure. Vic replacement filter. No leaks, no air in the lines, no noticable change in performance, just increased FC.
Hi Dieseldude,
I just bought a 2006 Starex CRDI with around 50T mileage. The engine seems fine if I don't press on the gas pedal to the metal. But if I need the power and I step on it, the engine just blows thick black smoke. I recently changed the oil and air filter, but it still emits black smoke. On top of that, my fuel consumption is only around 6 or 7kms/liter. I would love to hear from you. Thanks.
Eric
Thank you sir.
I suspected that it was running a little rich because of the new filter as well - just had to hear it from an expert. I will confirm if this is indeed the case when I change the air filter soon. Should balance out the added fuel and burn it more throughly, giving better FC figures.
Sir Dieseldude,
Ford Ranger 2005 Turbo diesel naka 78k+++ na sa odometer, mausok na, as per advise ng Ford greenhills kahapon nag pa change oil kasi ako ipa calibrate na, most likely gaano katagal ang calibration process at magkano aabutin? thanks![]()
dieseldude, pls. help.fortuner 3.0 diesel 90t km. pag naka park descending. pag mag start ako ng engine bigla n lang magbackfire unf tailpipe at magkakaroon ng heavy smoke na amoy nasunog.after 1 min back to normal na ang buga sa tailpipe. ano ba ang problem?
Sir DieselDude,
I have an Innova E diesel 2008 model. Already 67k odo reading.
1. Is it already due for injectors / nozzles cleaning maintenance? Can I have it serviced outside casa? (I don't think casa does this cleaning..)
2. "Tire-screeching" like sound is heard whenever I step on the accelerator after gear shift to 3rd or 4th at <=1700 rpm. No screeching if I shift gear at 2000rpm. Any problem on the screeching sound?
thank you in advance.
Sir DieselDude,
1. Is it already due for injectors / nozzles cleaning maintenance? I don't know if Toyota recommends this as part of their preventive maintenance system.
Can I have it serviced outside casa? (I don't think casa does this cleaning..) . You can have this done outside casa. Just be sure that the diesel workshop is well qualified to perform common rail service. Special tools & equipment and trained personnel are necessary for this type of work.
2. "Tire-screeching" like sound is heard whenever I step on the accelerator after gear shift to 3rd or 4th at <=1700 rpm. No screeching if I shift gear at 2000rpm. Any problem on the screeching sound? No problem. You may just have to alter your driving style.
thank you in advance. You're welcome...
dieseldude help naman, i have a toyota liteace and im planning to change engine from 5k to 2ct engine, i just want to know what are the advantages and disadvantages on having 2ct engine. sirain ba to o magandang engine. some mechanics say that its a disposable engine, is it true? i want to know what you think.i posted on the other thread pero no one replied or commented. i think they dont know what to say. maybe you can answer dieseldude. tia!
