sir mas ok po b tlaga yng crdi kaysa sa conventional diesel engine? nagbasa kasi ako ng review ng toyota's d4d sa hilux n innova..ang daming horror stories like engine knock, biglang humihinto yng makina tpos yng isang [papunatang baguio, nabitin yata..
plan kasi ng mom ko bumili ng innova..pro after reading the reviews..parang napa isip kmi..last sunday nagpunta kmi sa car show sa fort..nakita namin yng montero n san ta fe..ano kaya ang mas ok bilhin? sabi kasi ng danta fe agent, mas fuel eficient daw sila and combortable ang ride?
thanks
sir mas ok po b tlaga yng crdi kaysa sa conventional diesel engine? Shempre naman, ok talaga ang CRDI engines.
nagbasa kasi ako ng review ng toyota's d4d sa hilux n innova..ang daming horror stories like engine knock, biglang humihinto yng makina tpos yng isang [papunatang baguio, nabitin yata.. Totoo yan.
plan kasi ng mom ko bumili ng innova..pro after reading the reviews..parang napa isip kmi..last sunday nagpunta kmi sa car show sa fort..nakita namin yng montero n santa fe..ano kaya ang mas ok bilhin? Basahin nyo ang mga posts sa Tsikot, tapos mag decide kayo. Mas mahal ang Montero at Santa Fe kaysa sa Innova.
sabi kasi ng santa fe agent, mas fuel eficient daw sila and combortable ang ride? Shempre sasabihin yan ng Santa Fe agent. Pero maaring totoo din ang sinasabi nya. Mabuti nga na nandito ang Tsikot para makapag survey kayo.
thanks
Hi Dieseldude. Need your help. I was one of those who unfortunately got my Pajero submerged (near the roof for ~ 6 hrs) last September. Got it running after ~2 weeks but has had some problems once in a while. Last wednesday, after a few minutes of drive, the AT light started blinking so after driving for awhile to drop off my brother, i went back home. But i noticed that it was not shifting correctly already and it had a hard time getting up our driveway which has a small incline. I checked the ATF and it was full. I started it again, the blinking stopped and the power is back. Yesterday, we changed the ATF but didn't help much. The problem is intermittent. What should i check/do? Thanks.
I would check the throttle potentiometer for loose/broken wires. This is a black round thing with three wires, mounted on top of the injection pump's control lever. Don't loosen the 2 mounting screws or adjust it's position; this is critical. This device detects throttle position and sends a signal to the transmission control unit for proper shifting.
Update us if your fix is successful.
