Results 1 to 20 of 2351
    Apr 2010
    Quote Originally Posted by Dieseldude View Post
    I would like to help! Throw in your questions regarding problems with your fuel systems (injection pumps/ injectors/ turbochargers/ electronic systems/ etc.....) Then you guys take it from there...................if I can be of help, why not!
    Sir ask ko po kung ano ang problem ng starex ko 2003 model automatic. kasi habang ako ay nanakbo then pag nag slowdown ako ay namamatay ang engine.minsan kailangan ko pa palaging tapakan ang gas o i-hand brake para hindi mamatay. ano maganda solution po.thanks
    Sep 2006
    Quote Originally Posted by uly_141 View Post
    Sir ask ko po kung ano ang problem ng starex ko 2003 model automatic. kasi habang ako ay nanakbo then pag nag slowdown ako ay namamatay ang engine. minsan kailangan ko pa palaging tapakan ang gas o i-hand brake para hindi mamatay. ano maganda solution po.thanks
    Check / replace fuel filter. Baka barado na ito, o baka pinapasok ng hangin ang fuel system. Kelan yung huling fuel filter replacement?
    Apr 2010
    sir diko na matandaan matagal na di na check. ilan taon po ba ang buhay ng afuel filter?
    Sep 2006
    1 year max. Aralin mo owner's manual.
    *dieseldude
    engine is 4d56 NA in a mitsu L3FB ... problem is ... upon running for a few meters and slowed down or stop, engine shakes heavily that I need to rev the engine higher to keep the engine running ... failing to step on the accelerator pedal would cause the engine to die ... I used to experience this engine behavior when I'm low on diesel but now I am experiencing it even on half or full tank of diesel ... performed the following already: fuel filter check (it's clean/unclogged upon disassembly), fuel lines check (no fuel leak or air getting into fuel lines) ... currently, the engine emits a moderate amount of black smoke when revved. Do you think that the "engine shaking" might have something to do with the injection pump's or injectors' condition?
    Let me know your thoughts sir. I would really appreciate them.
    Thank you.
    Sep 2006
    Quote Originally Posted by putalittlemore View Post
    *dieseldude
    Thank you.
    What's your engine mileage?
    It could be a fuel filter or an injection pump problem.
    it's rather an old engine and was rebuilt twice already ... the last one being in December of 2009 ... according to the former owner, the last time the injection pump was checked was more than five years ago ...
Diesel Fuel Injection System Help Desk
