madami ako nkikitang mausok na 2.5 innova specially pag biglang tapak ang driver. Pero in my case sa strada wla ko nkitang smoke na mkikita mo sa side mirror while cruising 180 km/hr. Check mo sa casa, alam ko yan amg madalas na reklamo ng mga innova owners. Totoo yan dahil mas madami ang Innova kaysa Strada DID.
Diseldude bkit yun hi ace d4d ng pinsan ko gingamit sa pamasada pero wlang usok, but yun innova same engine sila pero mausok yun iba at injector problem. Hindi natin alam yan. Dalawang sasakyan lang ang comparison natin. Baka na tyempo lang na may problema yung Innova...
meron ba silang difference sa internal parts like injectors? thanks. Hindi ko alam dahil hindi pa ako nakakita or naka repair ng Hi Ace injectors.
. Brought it back to them, checked the injection pump, diagnosis was a worn automatic transmission. Brought to to Banawe have my transmission checked by Baltak however they were not convinced it was a transmission problem, change my ATF. Fuel filter changed still no avail, turbo changed still no avail, they then told me that it was the injection pump. Returned to Rapide to have my injection pump checked again. After checks & adjustments still no avail & insisted that it was the transmission. Returned to Baltak (Rapide is 2x expensive!) for transmission change, checked it again still not convinced & brought me to denso. Denso told me "sakal" ang injection pump tried some adjustments and certain that it was the culprit, called Rapide
told them of Denso however they insisted the transmission. Denso brought down the injection pump, culprit clogged due to worn rubber probably improperly installed! Recalibration also done-problem solved!
