Page 34 of 62 FirstFirst ... 2430313233343536373844 ... LastLast
Results 661 to 680 of 1227
    Jun 2013
    #661
    errr...
    with all due respect,
    do you have numbers?
    without numbers kasi, baka placebo effect lang.
    Fuel consumption ko before consistent 6.9 to 7.2km/L, at average 18km/h. Ngayon di bumababa nasa 7.5 to 7.7km/L, same average 18km/h. It is worth noting that I also replaced the 1 year old air filter though. Medyo marumi na, hindi na lumulusot ang ilaw.
    Yung singaw ng engine bay, wala ako nung thermometer na baril eh. But I always open the engine bay after a long hard drive since there a few ecoboost owners who seem to have coolant loss due to the engine block cracking supposedly because of heatsoak. It’s usually uncomfortably hot but now the heat emanating from it is quite tolerable. But as you said, baka placebo effect lang nga since I really can’t provide any numbers when it comes to engine temperature. But the fuel consumption is a real noticeable improvement though.
    Jun 2013
    #662
    Heat is more a function of the cooling system not lubrication.
    Yun nga rin naisip ko but it’s there. I didn’t touch the cooling system. Yun lang ginawa ko. The engine bay feels less hot when opened. Placebo effect or maybe timing lang? Possible. But that’s just something I personally felt and noticed. I really was expecting it na sumingaw ng sobrang init tulad ng dati since as far as I know, wala naman kinalaman ang oil sa pag cool ng engines.
    Dec 2013
    #663
    Actually nakakatulong ang good engine oil sa lesser heat generation pero hindi solely nakasalalay doon, a good engine oil makes engine parts cause less friction with each other, when there is less friction then less heat generation then also you got to consider if the lesser friction then the engine would operate more smoothly with exerting too much gas/diesel being injected sa kada cylinder, overall the vehicle will operate a lot more smoothly.
    Dec 2013
    #664
    Thanks. Akala ko kasi Aisin, related to Toyota or something. I’ll just stick with Bosch or Wix then.
    Aisin is related to Toyota pero the aftermarket products are not the same with Toyota anymore, they decided to outsourced almost everything for the aftermarket. First of all Aisin doesn't even produce lubricants and filters, the "Aisin aftermarket" is a different division na as they are solely doing aftermarket products by trying to outsourced their products from different China factories then packing it under the Aisin brand name. The clutch disc and pressure plate are the only products for the aftermarket that are being produced by Aisin's own factories, the rest of the aftermarket products are outsourced even the brake pads.
    During Engine testing & validation they use their recommended oils ...fulll power testing ...yes pls.
    #666
    Quote Originally Posted by JapanABC View Post
    in the case of aisin-advics may feedback na sila mula sa ibang SEA countries?
    Oct 2005
    #667
    May mga alam ako kung sino ang authorized dealers ng JS Asakashi filters sa Lazada and Shopee.
    Kapag bumili kayo sa mga link below for sure 100% original kasi naverify ko na sila sa JS Asakashi official distributor, for sure I can assure you 100% from the shops below.
    Ito ang mga alam ko authorized dealers ng JS Asakashi:
    Shop at F2 Auto Parts | lazada.com.ph
    Shop at ROADSIDE | lazada.com.ph
    Shop at Hobbies N' Stuff | lazada.com.ph
    The rest hindi pa naverify ng distributor ng JS Asakashi.
    Nag message ako sa FB ng Hesler. Add ko na din AG Auto piyeza, Ideal Automotive Components sa lazada. Authorized dealer ng Wix and Js filters.
    #668
    im looking for an alternative oil filter and im choosing between baldwin, wix and js asakashi.
    car is 1997 honda civic. currently installed is vic 809.
    sa lazada ako tumitingin.
    baldwin 1402 is at 400+.
    js c809j ranges from 180 to 300.
    wix i have no idea anong compatible sa oto ko. anyone?
    if ever i'll go with JS if wala ako mahanap na wix counterpart.
    Quote Originally Posted by jtiro View Post
    Baldwin, wix or Purolator if may mahanap ka. Amsoil and Mobil filters baka meron din.
    Bosch then Vic next level down.
    Sakura at JS naman if wala pa din talaga.
    For oil go with the recommended viscosity and API rating. Synthetic if matagalan palit like me na 1yr or if 6months or less or 5K whichever is earlier eh pwede na mineral oil para cheaper.
    basic yan B1402. Mahal kung 400+
    punta ka sa araneta avenue yung sa guirayan street meron doon nagbebenta baldwin at fleetguard (cummins)
    Meron yung ginagamit nya sa heavy duty eh ginagamit sa BRZ at yung pinsan nya naka toyota 86. Same fit din sa honda civic kasi dati ganyan kotse ko vti
    Nalimutan ko yung code pero puntahan mo. May advertisement yun sa carousell
    Jul 2014
    #671
    B1402 fits most Honda, Kia (Rio gas, etc), Hyundai (Accent gas, etc), Nissan (Almera, etc), Mitsubishi, Subaru, and Toyota 86. You can also explore wider/longer filters like B1431, B7243, B179, B161-S.
    Sent from my CPH1911 using Tapatalk
    #672
    Quote Originally Posted by Mask Rider Blac View Post
    Yep, Baldwin B1402 is compatible even with the Subaru turbo engines.
    Aug 2004
    #673
    Nice. Pwede palang magkaron ng konting kulay ang engine compartment. Green batt and red filter [emoji16]
    Same size as stock or slightly bigger? Yung BT223 kasi mas malaki compared to stock Toyota.
    Sent from my SM-A605G using Tapatalk
    #674
    It’s about the same size as the Subaru AA160 oil filter. The AA160 filter is preferred for the FA20 engine (XT, WRX, Levorg, BRZ, 86) while the shorter AA130 is the one mostly used on the FB20 (Impreza, XV, Forester 2.0L NA).
    There are newer filters for Subaru that are blue in color. There is even a red one (STI) and a pink one (HKS).
    Pag baldwin , Sa k20 engine compatible ang b1402 & b1431.
    Sa truck namin bd28 lang naman gamit ko.
    naalala ko na itsura ng oil filter giangamit ko dati. Bale hindi sya corrugated sa upper part so makinis sya all out. Pero code hindi ko pa din maalala.
    yan mga binanggit nyo eh lahat may grooves
    Jul 2014
    #677
    Flutes tawag diyan, Kags. Halimbawa ung B1400, B1402, B1431, B33, B37, etc have 14 flutes - can be removed using a 14-flute filter wrench end cap. While, B1405, BT223, B179, B7243, B161-S, B243, etc have 15 flutes - use 15-flute end cap. Ung BD7028 (big brother ni BD28) walang flutes, makinis ung dulo, samantalang ang P551343 at P502008 na kasing lapad niya, ay may 15 flutes.
    #678
    *Ry_Tower - thanks sir. might go with baldwin 1402 if makahanap ako sa labas. nasa 400 kasi ung sa lazada. magkano ba usually price nun?
    regarding oil, currently using motul htech 10w40. plano ko un pa din gamitin ko. else, will try zic x7 10w40 or repsol etc, basta 10w40 sana. also, ok lang kaya bilin ko lahat ng gamit then labor na lang sa labas? sorry medyo ot.
    *kagalingan - thanks sir. parang familiar yan. i think siya ung nag start magdala ng baldwin and fleetguard dito, mura pa nung time na un sayang di ko pa sinubukan nun. if tama ung nakita ko, zic baldwin name niya sa fb.
    *Mask Rider Blac - thank you sir. i think pwede na ung 1402, medyo mahaba na ung 1431 based sa pics.
    hindi sya nagstart pero alam nya yung technicals yung micron sa loob at ano pwede gamitin/cross reference.
    kasi kung gagamit ka ng B1402 na 400+pesos eh maliit yan. Contakin mo kasi yung pinagamit sa akin same price lang din at mas pino yung micron rating. At malapad pala yun. Maluwag pwesto ng civic 6th gen walang tatamaan.
    kung address nung baldwin zic sa facebook eh araneta avenue eh yung pinsan or kapatid nya yan.
    #680
    *kagalingan - nakausap ko na siya. he suggested the baldwin b161s then paired with zic x7 10w40 (for gas engine).
Best Oil/Fuel Filters
