Mahal yung Amsoil EA filter coz its made of synthetic microglass media. Designed for extended oil change intervals. If you don't do an extended OCI sayang lang.
Yung Baldwin B1402 fits most OEM oil filter requirements. Check below for cross-reference:
BALDWIN B14 2 - Cross Reference | oilfilter-crossreference.com
sobrang overprice yung langis royal purple at amsoil. Tapos yung oil filter subcontract pa. Hindi naman sila mismo gumawa nyan.
More on marketing na style nila. Remember the father of marketing eh amerkano the car salesman.
Just follow the API ACEA GM ILSAC rating and viscosity. Hindi na gaano issue kung mineral, semi or fully.
and if diskumpyado kayo sa online delivery eh punta kayo doon sa nagtitinda sa true qc haggang gabi 10pm bukas pa!!!! Jan legit nagbebenta langis at filter. Doon lumalangoy ng bd28 at cummins na counterpart kaso hinid ako makakabili kasi wala ako desel and im not planning to own one. Im just pure gaso kind of guy.
#trueqcditonalahat
Most oils within the API SN/SN+, GM dexos2, ILSAC GF5, ACEA ratings with viscosities 5w30 or below are synthetic already. Yung mineral oil na low viscosity is 10w30 while yung mga semi-synthetic is 5w40.
Kung kotse mo requires 5w30 or 5w20 or 0w20, no choice ka but to buy fully synthetic. Unless of course, pasaway ka at di mo sundin yung manual.
yung malalabnaw usually fully synthetic na yan group III. Pag indicate lang na 100% eh group 4/group5. KAya ko sinabii na hindi na gaano issue kung mineral, semi at fully eh para hiindi na hahaba discussion kasi jan nagloloophole manufacturers sa technicality pwede ka tawagin fully kahit hindi PAO
So ang focus eh API and viscosity. KAsi kahit nakaufully pero if wrong viscosity eh pangit takbo.
Majority nakaindicate na fully eh not true fully. Jan umeepal si amsoil at royal purple kaya ang lakas makaoverprice. Pinapalabas na big deal pagka fully nila. Sayang ng pera.
so 750 per liter masyado na mahal sa panahon ngayon na madami choices. MAy ibang brand nasa 450 ba or 470 so hind na aabot ng 500pesos ILSAC at dexos na
Yun Signature Series nila yun 700+ for longer drain interval. They also have yun Amsoil OE 100% synthetic around 440 to 470 php yun for manufacturer recommended OCI.
Sent from my SM-G980F using Tsikot Forums mobile app
yung around 400 eh pwede yan pero pag 700 na kahit imarketing nya good for 20,000kms eh bibili na lang ako ng 400pesos at every 10,000kms ko papalitan so mas fresh yung next oil change ko.
the problem kasi with royal purple and amsoil yung pagmarketing nila eh more of trying to be special pero ang key lang naman eh follow the rating and viscosity. Masyado nila hinahighlight yung group 4 para makaoverprice.
If you back read, si dvldoc yung nagpasikat ng bd28 sa pinas. Pinoint out nya yung overpricing ni amsoil sa america pinapalabas na premium so you pay premium din.
Para mas magets nyo point ko. Iilan na kotse umabot 1million miles na basic engine oil ang gamit. So parang mga designer brand na lang yan amsoil and purple.
Pwede yung mindset na ganyan sa mga slightly older cars.
Ganyan ginagawa ko sa mazda 2 namin na naturally aspirated, cheaper oil and change every 6 months. Some modern engines with turbo requires oil which are API SN Plus certified now. May mga phenomenon na ngayon nangyayari na LSPI. I doubt most oils na tag 400 na binebenta dito sa atin can prevent LSPI.
meron yan API SN plus mura lang kaso hindi licensyado ni API pero nakaindicate sa lalagyan SN plus.
A bit segue...has anyone avail the Sludgenizer service? Looks oks ang principle..much better than the usual adding of flushing oil. What's your take on this? Bdway Japanese tech sya if that may add value info.
Mostly likely 3/4-16 ang thread size ng oil filter for the Fiesta. You can check online kung anong part numbers ang applicable for the Fiesta then cross refer with other brands.
Motorcraft Oil Filter FL-91 S Suitable or Ford Ecosport / Fiesta / Focus / Everest / Ranger / Escape etc.
Access Denied
GENUINE Baldwin BT223 Heavy Duty Oil Filter for Toyota RAV4, Rush, Innova, Fortuner, Hilux, Revo; Ford Fiesta, Ecosport, Escape; 2 11 Mazda CX-7 2.5L 4-Cylinder Engine
Sent from my CPH1911 using Tapatalk
Saw Volmax along B. Serrano Grace Park Caloocan is this their second branch or they relocate their gandara branch?
