Results 21 to 30 of 36
- Jul 2016
- 939
March 17th, 2017 08:03 AM #21I've heard the clip and YES that is rod knock. It wont affect anything, idle, power, etc especially at this point. My advice, no matter how tempting it is. Don't drive or turn on the engine.
Sometimes, you can get away with just a simple rod bearing replacement with a simple/slight knock. If you continue to use it and wait to make the knock more audible, you could be looking at replacing the crankshaft, conrod and oil pump.
Have it trailered to Fronte in Banawe na lang. Once stop shop, mechanics are good and the sell Hyundai parts.
Good luck!
- Jan 2010
- 283
March 17th, 2017 07:15 PM #22Idiots do the same exact things, the same exact conditions, the same exact parameters over and over and expect a different result.
Determine the cause of the symptom before deciding to tear the engine apart. And when the inevitable happens to tear the engine apart, study it carefully, document it to prevent making the mistake or recurrence of the symptoms. Do not just replace with or damaged parts. Do not be that neanderthal.
- Jul 2016
- 939
March 18th, 2017 01:30 AM #23Super duper rough estimate.
Pull down and install of engine from engine bay = 10k
Teardown of engine and replace crank shaft, conrod and bearing = 5k
Crank shaft surplus = 5k
Conrod 1pc. = 2k
Conrod Bearing 1pc. 1k
Oil pump = 10k
Head gasket and seals, misc... = 5k
Total roughly 40-50k.
Scenario #2, very light damage only on conrod bearing, 1pc con rod bearing = 1k
Pull down oil pan and loosen and install conrod bearing = 5k, "dukot method.")
Oil pan gasket, misc = 1k.
Total roughly of 10k only.
Add micropolish of crank if there is only a slight damage and oversize conrod bearing = 5k + 15k for mount and dismount of engine from engine bay.
- May 2015
- 9
BANNED BANNED BANNED
- Jun 2007
- 122
March 23rd, 2017 06:20 PM #25The noise sounds like a lose chain slamming on the sprocket. As oil pressure builds up the tensioner increase tension to remove the chain slack. Pudpod na yung ngipin ng tensioner nag nag aaply ng tension sa chain pag bumaba oil pressure. A bad bearing produce a continuous knocking noise.
Maghanap ka ng shop ng may ganitong tools:
Engine Stand
Micrometer
Dial Indicator
Torque Wrench
Torque Angle Gauge
Straight Edge
Oil Pressure Gauge
Hydrodynamic type bearing ang gamit sa engine hindi ball/roller type bearing. Nakalutang sa oil yung shaft.
- Apr 2017
- 1
April 25th, 2017 10:27 AM #26Hi, where can I buy a new cylinder head assembly for my father's Nissan KA24DE engine for his Nissan presage 1998 model (U30) na mura. I tried surplus sa banawe isa lang ang nag quote. Thanks.
- Jul 2006
- 37
May 18th, 2017 10:29 PM #27Overhauled my 95 Hyundai Grace van with 4BDAS engine upon advise of my trusted and reliable mechanic and finished just today. I find the engine very nice after the overhaul compared to the 22 year old engine then. Breaking it in starting today and injection pump will be retimed next saturday. It took 10 days for all the work from disassembly, machine shop (4 days), buying of spare parts and assembly courtesy of my ever reliable and trusted mechanic friend.
Decided to have it overhauled due to noises coming from the engine and the temperature seems to be on the high side most of the time. Not on the overheating range but constantly on the high side especially when traversing inclines.
Got the van imported from korea around September 2007. Upon opening the engine, we found out that it had been top overhauled once. Now it was totally overhauled after 130K kms and 22 years of engine life.
Expenses in PHP as per below:
1 set Cylinder Head Assembly 4D56 14500
1 set Engine Parts 4D56 15000
1 Lot Machine Shop Works 14500
1 Lot Engine Works (Assembly/Disassembly) 8300
1 pc Crankshaft Pulley 1900
1 set Overhaul Gasket 1800
1 Lot Diesel Oil 972
4 pcs 1 Liter Coolant 600
1 pc Alternator Hose 350
2 pcs Gasket Beta Grey(Gasket/Sealant) 300
1 pc Power Steering Fan Belt 300
1 pc Oil Filter 250
1 pc Power Steering Fluid 150
1 pc Cement Sealant 100
1 Lot Screws 15
Total 59037
Bloody expensive. Hope the engine will last for at least ten years and more.
- Apr 2008
- 6,235
May 19th, 2017 01:21 AM #28^Very expensive indeed. It would've probably been cheaper to have a surplus engine swap, even with a stronger unit like the 4D56 TDIC. I hope you'd find the expenses worth it in the long run...
Sent from my SM-G900I using Tapatalk
- Jul 2017
- 16
October 26th, 2017 10:14 AM #29Mga sir gandang hapon po! Sorry po newbie lng po pagdating sa sasakyan. I am driving a mazda 3 2004 model. Tanong lang po if may idea po kayo kung mgkano po mgpa top overhaul and san po kya may maaus na talyer at idea po kung magkano abutin? Recently po kasi nag overheat ung sasakyan ko and kala ko po dala lang ng leak sa water overflow reservoir which napalitan ko na po ngaun ng bago but still unti unti pa rin po nauubos ung tubig sa reservoir. Tapos po knina pag check ko po sa oil dipstick at engine oil cap may sludge po na prang kulay gatas po. Sabi po ng friend ko bka may tama na daw head gasket ko. Sana po matulungan nyo ko. Mejo tight din na po kasi budget ko.
Ask na rin po sana ako if safe pa po ba idrive ito? Right now po ngsstart na po ako mgipon ng pera dahil ang sabi po sa akin maghanda na daw ako ng budget at mahal daw po mgpa top overhaul... please po tulungan nyo po ako.... salamat po
- Dec 2010
- 3
December 27th, 2017 04:14 PM #30
I have those "Fire Stop" brand extinguishers by the driver's door cup holder/pocket. I don't think...
Fire Extinguisher for Car: what brand and type...
