Results 1 to 20 of 36
    Jun 2007
    The noise sounds like a lose chain slamming on the sprocket. As oil pressure builds up the tensioner increase tension to remove the chain slack. Pudpod na yung ngipin ng tensioner nag nag aaply ng tension sa chain pag bumaba oil pressure. A bad bearing produce a continuous knocking noise.
    Maghanap ka ng shop ng may ganitong tools:
    Engine Stand
    Micrometer
    Dial Indicator
    Torque Wrench
    Torque Angle Gauge
    Straight Edge
    Oil Pressure Gauge
    Hydrodynamic type bearing ang gamit sa engine hindi ball/roller type bearing. Nakalutang sa oil yung shaft.
    Apr 2017
    Hi, where can I buy a new cylinder head assembly for my father's Nissan KA24DE engine for his Nissan presage 1998 model (U30) na mura. I tried surplus sa banawe isa lang ang nag quote. Thanks.
    Jul 2006
    Overhauled my 95 Hyundai Grace van with 4BDAS engine upon advise of my trusted and reliable mechanic and finished just today. I find the engine very nice after the overhaul compared to the 22 year old engine then. Breaking it in starting today and injection pump will be retimed next saturday. It took 10 days for all the work from disassembly, machine shop (4 days), buying of spare parts and assembly courtesy of my ever reliable and trusted mechanic friend.
    Decided to have it overhauled due to noises coming from the engine and the temperature seems to be on the high side most of the time. Not on the overheating range but constantly on the high side especially when traversing inclines.
    Got the van imported from korea around September 2007. Upon opening the engine, we found out that it had been top overhauled once. Now it was totally overhauled after 130K kms and 22 years of engine life.
    Expenses in PHP as per below:
    1 set Cylinder Head Assembly 4D56 14500
    1 set Engine Parts 4D56 15000
    1 Lot Machine Shop Works 14500
    1 Lot Engine Works (Assembly/Disassembly) 8300
    1 pc Crankshaft Pulley 1900
    1 set Overhaul Gasket 1800
    1 Lot Diesel Oil 972
    4 pcs 1 Liter Coolant 600
    1 pc Alternator Hose 350
    2 pcs Gasket Beta Grey(Gasket/Sealant) 300
    1 pc Power Steering Fan Belt 300
    1 pc Oil Filter 250
    1 pc Power Steering Fluid 150
    1 pc Cement Sealant 100
    1 Lot Screws 15
    Total 59037
    Bloody expensive. Hope the engine will last for at least ten years and more.
advice on engine overhaul or surplus ?
