Results 171 to 180 of 193
July 25th, 2013 12:49 PM #171
Wow, nice jumper cables. I used welding cable for mine, but I did not solder the wires, I drilled holes on the clamps and screwed them tight. It's been in service for about 5 years, has never failed me.
- Nov 2009
- 3,507
July 25th, 2013 06:08 PM #174
desperate measures. if you were in the jungle maybe.
first, the alternator needs a battery to work, weak battery, weak charge rate, it will charge eventually but may take considerable time depending on state of charge
second, the alternator can be spun either way, that is why it is an alternator. the old 6 volt charging system of the willy's jeep used a dynamo which reverses in polarity when spun backwards. the alternator on the other hand can be spun your way like burger king you can have it your way. the best way to charge a battery is from a battery charger not the chainsaw nor another car. charging with a shop charger pushes a deep charge
there are desperate ways, an example is the gmac 6X6 cckw two and a half ton truck, could be started using rattan vine wrapped around the pulley to use as a starting rope
July 25th, 2013 06:11 PM #175
may sobrang wire sa bahay 500MCM THW naka crimping lugs pwede rin bang gamitin ito pang jumper?
- 54,211
July 25th, 2013 10:29 PM #176you can still use soldering wire with rosin core, but you will have to feed it fast! mebbe if you can source the thicker size..
or you can use the lead bar they use in radiator shops. but you need to get some rosin to add to the parts you are gonna solder, to make the metals stick well.. kahit sa ace, meron nyan.
and you can use a small blowtorch, to heat it faster and evener..
i know this system works, because we have used it before, to solder battery cables to battery clamps.
good luck.Last edited by dr. d; July 25th, 2013 at 10:33 PM.
- Jun 2005
- 3,774
July 25th, 2013 10:40 PM #177
- Nov 2009
- 3,507
July 26th, 2013 12:00 AM #178If you are referring to the seamless lugs, like this one laying around my box.
You may solder it
But the proper tool is this hydraulic crimper. No soldering needed.
- 54,211
July 26th, 2013 12:11 AM #179the one in ace is fine.
the metal pieces you are going to solder together, have to be shiny. sandpaper them. the rosin helps the solder to stick to the metals. and the metal pieces have to be good and hot, for the solder to work well. that is why you need a big heat source, like a small blowtorch or an industrial soldering iron.
and there are some metal types you can not solder, because solder won't adhere to them.. aluminum, stainless steel,
to the guys who prefer crimped ends, the stores selling these cables may have such crimping tool to assist customers with..
July 26th, 2013 05:30 PM #180
OT:
The "deuce and a half". We had them in farm service way, waaaay back, converted to Isuzu 6BB1 engines. Even in waist deep mud, these trucks can pull themselves out, loaded pa ng tubo yan ha.
I still have a technical manual for these trucks.
Technical Manual TM 9-801GMC CCKW-352 CCKW-353 CCW-353
What do you guys think of this alleged defect of the 2017 a/t models? ...
The Toyota Fortuner has landed (fortuner pics at...
