Results 161 to 170 of 193
- Nov 2009
- 3,509
July 25th, 2013 01:28 AM #162Done with my custom booster cable. 15ft, 25mm2 AWG3, largest Panther clamp at Deeco.
More than thrice the weight of the commercial booster.
- Nov 2009
- 3,509
July 25th, 2013 01:55 AM #163Challenging part is the crimping and soldering.
Cold solder
Can't complain, im using cheap soldering station limited to 480C
Solution.. Torch it
Nice and neatly cooked solder
- Jun 2005
- 3,774
July 25th, 2013 08:28 AM #164
July 25th, 2013 08:49 AM #165
when you solder electrical components, use rosin core flux, do not use acid core or solder and acid cleaner like what you see them use on radiators
How to Solder battery terminals - YouTube
Solder - Wikipedia, the free encyclopediaLast edited by jick.cejoco; July 25th, 2013 at 08:53 AM.
- Dec 2012
- 304
July 25th, 2013 08:50 AM #166
July 25th, 2013 10:04 AM #167
nosebleed ah.
anyway i have a fair share on this also. I left the dome light ng montero for more than 24hrs/coding day, ayun "click" sound lang pag start next day. Tried to jumper from my ASX using cheap jumper cable rated 300AMP - but i failed. So what i did was transfer the ASX batt to Montero and start it(success naman) - while montero(gls-v/diesel) idling, I removed the asx batt and installed back the monty's and left idle for 30+/-mins.
My friends told me that the ASX (1SM) couldn't start the Montero (3SM) batt kahit naka andar pa yun ASX dahil nga diff batts - true? O maybe cheap cables with weak clamps?
- Nov 2009
- 3,509
July 25th, 2013 11:27 AM #168Just ordinary 60/40 Rosin core 1.2mm,
*madduck - from spare wires of my inverter welder. 25mm2, around AWG3 based from the conversion chart.
Those clamps are made from steel with copper plating because pure copper can't be that strong. I couldnt find seamless lug-type clamps so I crimped it using ordinary punch. Seamless eye terminal lugs are good when crimped by hydraulic press, no soldering needed..
Im planiing to make 3 more for the other cars. Im giving away the old jumper wires.
- Nov 2009
- 3,509
July 25th, 2013 11:37 AM #169This is what im avoiding. When you need it, won't do the job, useless as leaving the jumper-wire at home.
Click sound is an indication of not enough current. Like previously discussed, could be clamps, crimps, and the wires. Also next time, leave the jumperwire for 15mins or more to allow the dead battery to charge as charging battery initially draws lots of current.
July 25th, 2013 11:57 AM #170
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
