Page 7 of 10 FirstFirst ... 345678910 LastLast
Results 121 to 140 of 193
    Oct 2011
    #121
    Jumper cable is a must for auto tranny vehicle.
    nahilo na ako sa thread. yun negative ba dapat i ground pa or hinde...? o flashlight na usapan?
    sariling gawa na jumper cable
    pang start ng 24V trucks and heavy machines
    di ko na kailangan problemahin ang amp rating amp rating na yan
    that's welding cable
    more than enough for any starter we got here
    Sep 2010
    #124
    i have a black and decker jumpstarter kit (since A/T oto ko). instruction
    nya is + to + (Jumpstarter kit to car batt)
    then - to car chassis/solid body part.
    reverse pag tapos na.
    Boost Ampere: 375 instantaneous cranking amps (according to the manual).
    Aug 2004
    #125
    Parang gets ko na kung bakit not recommended ang negative to negative terminal. May napanood ako sa Discovery Turbo (The Garage). Pekeng M3 ginagawa nila and namatayan ng battery sa shop kaya ni-charge muna. After a few minutes charging nagstart na so tinanggal na ng mekaniko ang clips ng charger. Biglang BOOM! Yun pala di nya na-unplug muna ang charger bago tinanggal ang clamps. Nagspark pagtanggal and nag-ignite ang gases sa loob ng batt. Takbo agad sa CR ang mekaniko para maligo.
    So if nasa block or body ang ground connection mo pagtanggal less chances mag-ignite dahil malayo sa battery. Once natanggal na yun wala nang circuit so safe na tanggalin ang iba.
    #126
    ganto na lang, kung ayaw neg to neg, edi lagay sa body neg.
    edit: sa jumper cables, Ewan ko ba kung bakit kailangan alalahanin amp rating, basta gumagana ok na yan. kahit kasing kapal pa ng braso, 12v to 12v or 24v to 24v, yan pa rin ang dadaloy na voltage.
    when you're charging a battery using a charger the battery gets warm and the battery acid will bubble and you'll smell acid vapor
    but that doesnt happen immediately after you connect the charger. it takes several minutes before that happens
    connecting a good battery to a dead battery is like connecting a battery charger to the dead battery. it's not gonna make the dead battery charge up agad and release vapor
    so it's unlikely a spark will cause the dead battery to explode
    overly cautious lang ang mga Kano kasi ayaw nila mademanda
    wala naman pumipilit sa inyo mag neg terminal to neg terminal
    use body ground all you want
    like cathy did. she followed step by step instructions pero di niya na-start car niya. may nagsabi tuloy stuck-up na makina niya
    pero napaandar niya noong pinalitan niya ng battery
    so what went wrong?
    suspetcha ko body ground. mali location pagkalagay ng cathy. kung nilagay niya sa neg terminal umandar sana yan
    in those few seconds kukulo ba ang battery acid at magrelease ng vapor? i doubt it
    #129
    Anlake! Yung DIY ko from inverter welder kaya gauge 3 lang, pero palagay ko kaya din magstart ng 24V neto. Pwede din double purpose, tow cable..haha
    Dapat well ventilated. Hydrogen buildup nangyari.
    Quote Originally Posted by [archie] View Post
    Dapat consider wire gauge, ang analogy ng wire is parang tubo ng tubig. The larger, the more current could pass. Kung malaki ang amp draw ng starter at solenoid, iinit lang ang wire (electron congestion).
    As a general rule based fron nabasa ko - gauge 6 for small cars, extending the length increases the resistance so u have to increase the gauge, the bigger/shorter the better.
    #130
    umabot pa sa transmission and pulley, labo.
    Oct 2011
    #131
    Kailangan pa bang mag suot ng jumper suit habang nag jujumper?
    #132
    based kasi lahat sa "nabasa". pwede naman subukan muna.
    #133
    oo, tapos properly insulated shoes and rubber gloves. o ya don't forget mask, pero kung wala, pwede rin helmet na full face na with proper padding.
    ay oo
    required
    sobra
    #135
    Subukan niyo na rin ito:
    Pasado sa lahat ng klase ng National, International, Universal at Inasal Standards kasama pati
    ANSI standards + ISO, IEC, DIN ASTM, ASHRAE, INCITS, NFPA & more... :hysterical:
    #136
    Retz, seriously? :rofl:
    Pinost na ni uls yung proper attire pag gagamit ka ng jumper cable
    Sent from my GT-N7100 using Tapatalk 4 Beta
    #137
    Patay ka din sa hazmat jung hydrogen bomb este hydrogen buildup sa battery.
    Eto proper suit for handling battery.
    yung hazmat suit?
    haha that was a joke... pero kung gusto mo pwede din
    haha
    ayan
    pang bomb squad
    #140
    yung hazmat suit?
    Of course I know :bwahaha:
Jumper cable amp rating
