Page 2 of 10 FirstFirst 123456 ... LastLast
Results 21 to 40 of 193
    usually positive muna but not coz we're following procedure but coz nakasanayan na
    ang rule lang naman huwag ma-baligtad huwag dumikit
    Oct 2011
    #22
    jumper lang yan i-parallel lang ang baterya. dami pang procedure na positive muna, negative naman sa ground dapat. etc...
    it's an 8 step process haha
    Jul 2010
    #24
    Bakit kaya SERIES ang tawag ng mga mechanic noong unang panahon pag jumper sa battery? Eh PARALLEL connection naman ito.
    Oct 2011
    #25
    bagsak cguro sa basic electricity 101.
    #26
    Quote Originally Posted by Chinoi View Post
    Sa mga matatandang mekaniko ko na nga lang narinig 'yang SERIES na 'yan.
    Noong High School years ko, natanong ko sa matandang mekaniko namin
    "Tatang, bakit po pag nagja- jumper kayo sa baterya eh sinasabi niyong I- SERIES MO NGA 'YUNG BATERYA?
    Ang tamang tawag po kasi sa ganyang koneksyon e PARALLEL."
    Sinagot niya naman ako ng tanong rin:
    "O e di ba pag ikakabit, sa ingles eh SERIES?"
    Sa tanong pa lang niya, nakuha ko na ang sagot sa tanong ko. Napa- ngiti na lang ako...
    May 2013
    #27
    Strictly speaking, it is a series connection because only a single load(car to be jumped) is connected to the single source(battery). Electron flow during jump start only occurs in a single loop. Yes, the batteries will be connected in parallel(source to source) but the car would be in series with the battery(or batteries in parallel).
    Sent from my HTC One X+ using Tapatalk 2
    Oct 2011
    #28
    ah okay. un pala ang explanation kung bakit series.
    #29
    ^ Wrong
    If you series the batteries it will produce 24 volts.
    #30
    Reason behind positive first is for safety.
    Bridging negative first could pose great chances of positive accidentally touching the negative since the surroundings(car chassis) is already electrically negative.
    Same safety practice for -48VDC Datacom/Telecom setup, but it uses negative as the "hot" wire (chassis being positive).
    May 2013
    #31
    ^ Wrong
    Yes, the batteries are in parallel during jump start (+ to + and - to -). The series connection refers to the connection of the starter(load) and battery(source).
    While this is the case, I am not certain if this is why some call this a series connection. Maybe nakasanayan na lang din.
    Regarding jump start procedure, wouldn't it be safer to connect negative first? I believe the body is connected to ground(negative terminal of battery). If one were to connect the positive terminals first and somehow touch both car bodies without insulation the person would complete the circuit, possibly causing the current to pass through the person. As opposed to when we connect negative to negative first, where there is very little chance of accidentally connecting the positive terminals because of the relatively lesser exposed metal connected to them. Of course, this is based purely on electrical theory and I'm very open to correction. Wisest would be to follow what is stated in the user manual of your vehicle.
    As for jumper cable current rating, I'd go for at least double what your starter is rated.
    Jun 2012
    #32
    In a sense, may be true if the mechanic is careless.
    On the other hand, connecting the positive first, by the same careless mechanic and accidentally connected the negative of the jumper to a circuit more negative than the positive but more positive than the negative, then think about what will happen.
    Jun 2012
    #33
    Quote Originally Posted by alexverzosa View Post
    Correct.
    During jumpstart, you are not connecting two batteries but a load so you can not say it is "parallel".
    #34
    Maybe the term was coined from early training on basic electricity like how to connect a light bulb of a flashlight using 2pcs size D batteries in series. Even if you put the starter (load) to the battery (source) it will still be in parallel.
    For DC system, positive first for safety. Chassis having the larger surface area(surroundings) is electrically negative. For AC system esp unbalanced transmission, lage grounding at neutral side ang una for safety.
    When buying jumper cable, inspect the quality of wires and how good the clamps and the crimping. The finer/heavier the strands on the same wire gauge means it could carry much current than those having larger strands.. Those in the market mostly are overrated so id suggest get the highest rating as possible just to be sure. Another is, during jump starting if you are unsure how good the car's chassis ground, id suggest clamp it directly to the negative terminal. I tried jump-starting L300 using Gauge 12 3C royal cord bolting it directly to the clamps. Considering diesel takes time to heat the heater and have larger starter motor, i would assume even a 150Amps cable would do the job for a gas engine.
    #35
    [QUOTE=alexverzosa;2179839]Yes, the batteries are in parallel during jump start (+ to + and - to -). The series connection refers to the connection of the starter(load) and battery(source).
    because they did not know any better..?
    besides, it is easier to say series than it is to say parallel..
    Jun 2012
    #36
    Thevenin's Theorem states:
    Any linear electrical network with voltage and current sources and resistances can be replaced at terminals A-B by an equivalent voltage source Vth "in series connection" with an equivalent resistance Rth.
    #37
    Quote Originally Posted by confused shoes View Post
    i think it means, you connect the other car's battery in series with the starter of the car with dead battery, and, necessarily, in parallel with the dead battery.
    Jun 2012
    #38
    Correct dr.d.
    In this case, the dead battery is already a load (no longer a source) and is receiving current from the live battery.
    #39
    That is true when you consider the wires as part of the resistance.
    But Kirchhoff's law states " in parallel circuit the total current is the sum of the currents through the individual components"
    Oct 2011
    #40
    Kung ang dead battery ay considered na load edi magiging simple series circuit yan. But could we consider the dead battery as a load? Baterya or source supple un eh mahina lang nga voltage.
Jumper cable amp rating
