Results 31 to 40 of 193
- May 2013
- 5
July 11th, 2013 08:32 PM #31Yes, the batteries are in parallel during jump start (+ to + and - to -). The series connection refers to the connection of the starter(load) and battery(source).
While this is the case, I am not certain if this is why some call this a series connection. Maybe nakasanayan na lang din.
Regarding jump start procedure, wouldn't it be safer to connect negative first? I believe the body is connected to ground(negative terminal of battery). If one were to connect the positive terminals first and somehow touch both car bodies without insulation the person would complete the circuit, possibly causing the current to pass through the person. As opposed to when we connect negative to negative first, where there is very little chance of accidentally connecting the positive terminals because of the relatively lesser exposed metal connected to them. Of course, this is based purely on electrical theory and I'm very open to correction. Wisest would be to follow what is stated in the user manual of your vehicle.
As for jumper cable current rating, I'd go for at least double what your starter is rated.
July 11th, 2013 08:46 PM #32
In a sense, may be true if the mechanic is careless.
On the other hand, connecting the positive first, by the same careless mechanic and accidentally connected the negative of the jumper to a circuit more negative than the positive but more positive than the negative, then think about what will happen.
July 11th, 2013 08:54 PM #33
- Nov 2009
- 3,484
July 11th, 2013 09:00 PM #34Maybe the term was coined from early training on basic electricity like how to connect a light bulb of a flashlight using 2pcs size D batteries in series. Even if you put the starter (load) to the battery (source) it will still be in parallel.
For DC system, positive first for safety. Chassis having the larger surface area(surroundings) is electrically negative. For AC system esp unbalanced transmission, lage grounding at neutral side ang una for safety.
When buying jumper cable, inspect the quality of wires and how good the clamps and the crimping. The finer/heavier the strands on the same wire gauge means it could carry much current than those having larger strands.. Those in the market mostly are overrated so id suggest get the highest rating as possible just to be sure. Another is, during jump starting if you are unsure how good the car's chassis ground, id suggest clamp it directly to the negative terminal. I tried jump-starting L300 using Gauge 12 3C royal cord bolting it directly to the clamps. Considering diesel takes time to heat the heater and have larger starter motor, i would assume even a 150Amps cable would do the job for a gas engine.
- 52,731
July 11th, 2013 09:13 PM #35[QUOTE=alexverzosa;2179839]Yes, the batteries are in parallel during jump start (+ to + and - to -). The series connection refers to the connection of the starter(load) and battery(source).
because they did not know any better..?
besides, it is easier to say series than it is to say parallel..
July 11th, 2013 09:18 PM #36
- 52,731
July 11th, 2013 09:24 PM #37
July 11th, 2013 09:31 PM #38
- Nov 2009
- 3,484
July 11th, 2013 09:40 PM #39
July 11th, 2013 10:15 PM #40
Kung ang dead battery ay considered na load edi magiging simple series circuit yan. But could we consider the dead battery as a load? Baterya or source supple un eh mahina lang nga voltage.
Xiaomi E-Car
