Results 21 to 30 of 117
December 9th, 2016 11:08 PM #21
i don't want to argue but is a collision at 30 kph strong enough?
forget it. i'll just stop at my suggestion to keep it in its box and be mindful where you place it inside your vehicle. safety first lang.
i have 1 myself btw.Last edited by yebo; December 9th, 2016 at 11:21 PM.
- Jun 2015
- 2,751
December 9th, 2016 11:24 PM #22
December 9th, 2016 11:28 PM #23
- Jun 2015
- 2,751
December 10th, 2016 12:20 AM #24
- Aug 2012
- 2,767
December 10th, 2016 12:32 AM #25
- Aug 2012
- 2,767
December 10th, 2016 12:40 AM #26By the way, the 300000 mAh advertised is obviously a typo error. 30000 mAh makes more sense. The cheap price also makes me wonder about the quality. My tire inflator alone costs more than that set.
Sent from my D5833 using Tapatalk
- Aug 2012
- 2,767
December 10th, 2016 12:46 AM #27I also have no idea bro. But consider this.. many uses dashcams with lithium batteries. Nakabilad pa sa araw. If 30kph collision is a major impact, dapat sumabog rin sila di ba? They would pose more danger since sa harap nakakabit ang dashcam. Close to the driver and front passenger.
- Feb 2014
- 2,694
December 10th, 2016 12:02 PM #28bumps won't cause it to explode. but if the outer shell is breached and the wires inside start crossing, or the cells get punctured then you'll have a nasty lithium-ion fire
a padded box won't be good enough. i recommend a tough metal box that would contain the fire as well
- Jul 2013
- 2,450
December 12th, 2016 10:11 AM #29Just buy a jumper cable. What are the chances your vehicle will stall? And what are the chances your vehicle will stall and there noone around to help you.
- Apr 2010
- 742
December 12th, 2016 11:17 AM #30how can it output the said spec of 150 - 300A jumpstart when it is 14Ah * 3.7v?
doubt all these powerbanks can juice a really dead battery. buy this primarily as a powerbank, not as a jumpstarter
If you don't have a spare tire, a tire inflator using the socket of the car as power outlet is the...
Liquid tire sealant
