Page 8 of 38 FirstFirst ... 45678910111218 ... LastLast
Results 141 to 160 of 754
    Feb 2009
    #141
    it is a 1996 corolla, right? what is your odometer reading? what is your engine type? this year of corollas are run on timing belt. any difference in sound as you are cranking? any unusual noise while cranking? i hate to say this but confirm first. don't rush into previous post guesses. like they said, it has become a science. better to be that way than guessing.
    dont rush into previous post guesses pero dapat i-consider mo guess niya haha
    ayaw lang mag start timing belt agad ang problema
    Feb 2009
    #143
    and who said it is confirmed timing belt? the problem with people is that they put their words into other people's mouth.
    so what happened to a systematic approach. diagnose first then operate, not the other way around.
    crank wont start so it's logical to think fuel or ignition yan
    hindi out of nowhere guessing yan
    #145
    Yes. It's a 1996 Gli. The odometer reading is 184012 na pala I already had the timing belt replaced when it reached 100k, I did not notice any unusual noise. I only tried to start it thrice. I turned the key all the way na pero ayaw tumuloy yung pagikot (?)
    What I want to find out is if this can still start from push start method? or there are less chances?
    so what the **** is wrong with our posts saying it could be fuel and ignition problem?!
    it's logical
    it's not like we're saying ayaw mag start coz it's a brake problem
    will you pls be clear about the cranking
    is it cranking but wont start? or cranking a few times then stopped cranking?
    Feb 2009
    #148
    it's logical
    sorry po, i just like to give some people heart attack. maybe i get successful
    hey cathy pacheck mo muna timing belt baka naputol hahaha
    #150
    Crank then stopped cranking kahit nakatodo pa yung turn ng key.
    e di overhaul na ko. Ayaw.
    Feb 2009
    #151
    what's your engine type/family? is it 3E, 4AFE?
    cathy eto panoorin mo --- exactly the same as your engine
    [ame=http://www.youtube.com/watch?v=064Ilsz8Fzg]Fixing A Car That Cranks But Doesn't Start Up - YouTube[/ame]
    #153
    My car's engine is a 4AFE
    #154
    Mas maganda pa yan. Yung akin parang isang ikot lang tapos kahit naka todo yung key wala ng ikot. Matagal na nga ako walang change oil Eh kasi two years na hindi pa ako nakaka 5k kms
    saan mo nilagay ang negative cable ng jumper sa dead car?
    baka kulang sa ground kaya ayaw mag crank
    #156
    Suot ka na rin neto Cathy baka magka gas explosion kaka jumper mo sa 1sn batt
    BTT: Crank it max 10secs so that your starter and solenoid won't overheat.
    Kung namamatay ang cranking,may problema starter mo(or baka maluwag jumper cable mahina current), dapat continous yan as long as nasa start position ang key.
    #157
    Sa bakal na hook malapit sa distributor. Nag spark nga pag kabit ko.
    Feb 2009
    #158
    if you have 4AFE, your engine is non interference type-meaning-even if your timing belt broke while the crankshaft was turning, it will not have severe engine damage because the valves and the pistons do not share the same space. it might sound locked up if :
    1- the camshaft lost lubrications and has seized
    2-the injector/s is/are leaking making the piston hydrolock
    3-the crankshaft is seized.
    4-funny as it seems, maybe an alternator, idler pulley, water pump or other accessory might be seized restricting free movement of the crankshaft pulley.
    5-if it was a manual transaxle equipped car, the clutch or transaxle maybe locked up
    6-hopefully, not your pistons seized in the cylinder bore.
    have tests done first. don't be a doctor prescribing open heart surgery before even exhausting diagnostic procedures
    #159
    None of those sound good
    kung malakas ang battery (the live one) , and the starter is fine, you turn the key but cranks only once or twice then stops cranking then something's stuck (di kaya paikotin ng starter ang makina). sana hinde. did you try lipat mo sa ibang part ng engine ang negative cable? or sa negative terminal mismo
How to Know If It Is Only A Battery Problem
