Results 31 to 40 of 754
June 4th, 2013 02:36 PM #31
bring the car to a battery shop
they'll use a hydrometer to check the electrolyte. they'll tell you kung sira na ang battery
they can also determine kung di kumakarga ang alternator
June 4th, 2013 02:40 PM #32
I can bring the battery but I can't bring the car. Wala akong jumper cable (naalala ko si lsb ) Pwede ko rin i push start worst case scenario...
If this ends up costing a lot of money,I am sure my Mom will make me sumbat that I should have sold the car a long time ago. Worse she might force me to replace it now with a Vios
Nakakatakot kasi yung umaandar na yung mga indicator naka red pa rin Araw araw naman pinapa andarLast edited by _Cathy_; June 4th, 2013 at 02:45 PM.
June 4th, 2013 02:46 PM #33
If it is the idiot lamp,- then the alternator is not charging the battery (it is basically an ammeter)....
The trouble with a battery is that it appears to be charging, and yet, not retaining the charge....
Sis,- there are some nice battery monitors that you can buy from Concorde,- you can just plug it in your cigarette lighter port and it will tell you the voltage across your battery more or less through LED... I'll post a couple of pics... Cost is about P350
There is a digital variant,- cost is about P995 (seen some at True Value ATC)....
I have one actually in my car,- i.e, if you are near Taguig (mahirap side)....
In conjunction with your ammeter(idiot lamp)- perfect monitor of your battery and alternator.
19.4K:tomato:
June 4th, 2013 02:47 PM #34
don't let auto shops/mechanics mystify you with mumbo jumbo and fancy equipment
they do that to make you think fixing your car is complicated so they can charge you more
June 4th, 2013 02:49 PM #36
This is the digital variant... Normally, when you are running the car with aircon and headlights, it should read 13V+ and you should have a healthy and robust setup
This is more or less the LED variant. Locally, a variant has 4 green LEDs and 1 red LED... If one green LED is on, your voltage is at least 10.5V
two green LEDs : at least 11.5V
three green LEDs : at least 12.5V
four green LEDs : at least 13.5V
You figure.
Another variant is a combination of red and green and yellow LEDs with various voltage equivalents.
All can be plugged in to your lighter interface. All our rides have one of these 3 variants.
Again,- in conjunction with your ammeter (idiot lamp monitor for battery charging),- you have an effective monitor for your battery and alternator... voltage + current,- they should correlate....
19.4K:tomato:Last edited by CVT; June 4th, 2013 at 03:00 PM.
June 4th, 2013 02:52 PM #37
June 4th, 2013 02:52 PM #38
June 4th, 2013 02:55 PM #39
*CVT I can't see the picture
Yung may parang gripo na icon naka light din. Basta lahat ng icon ata naka red pag naka andar. That was until yesterday nung umaandar pa.
June 4th, 2013 02:55 PM #40
Suzuki JIMNY [merged threads]
