Page 10 of 16 FirstFirst ... 67891011121314 ... LastLast
Results 181 to 200 of 306
    Quote Originally Posted by CLAVEL3699 View Post
    ilang araw ba bago madrain yung battery paghindi nagamit yung Car... 3days lang drain na yung battery ko.
    Mabilis yan pre. 3-5 days kahit may alarm 1 click lang diesel cars ko. Diesel pa yun, malakas battery requirement sa start-up.
    Either, battery is about to conk out, alternator problem or grounded somewhere. The usual culprits.
    #182
    Last may ko pa lang nabili yung battery kaso 8months warranty lang sya... With maintenance kasi.
    Tingin ko yung H.U. ko lagi kasing nakabukas or may grounded.
    Pinacharge ko kahapon mga 2hrs... isang start lang, pinaandar ko nang mga 5mins pinatay ko ulit pagstart ko ayaw nanaman.
    #183
    our cars start with the first attempt, even if they hadn't been touched for 2 to 3 weeks.
    batteries last longer, if they hibernate in fully charged condition.
    batteries deteriorate faster, if they remain un-fully charged for long periods..
    #184
    Sa experience ko, 'di naglalayo ang life span ng baterya sa warranty period nya.
    Dec 2014
    #185
    Noob question:
    Ang battery life ba depends on how often do you use car? or malaking factor din pag hindi laging ginagamit ang oto?
    1 year na oto ko and 6k pa lang mileage, got me worried baka biglang maubusan ako ng battery sa provincial roads
    Noob question:
    Battery life is affected by a lot of factors naman. But biggest killer is heat, vibration and not enough charging cycle. In your case 6K mileage in a year is low but not alarming enough to degarde battery. Basta proper warm-up bago bumiyahe and avoid 3-5 mins travel time or short trips. Give the engine fluids and battery enugh time to work and be fully warmed/operational. Huwag mo na lang i-off agad after a really short drive.
    #187
    Saken minumum of 3 years up to 3.5 years yung Motolite Enduro.
    #188
    may promo (na naman) ang motolite.. 2140 bucks lang..
    #189
    so the battery's worst enemy is the engine beside it...
    Sep 2013
    #190
    +101 here. add ko lang kung di gagamitin ng matagal ang car, may I suggest to disconnect the negative batt terminal (black color) . sa concern nyang baka ma-dead batt while on the road, isa sa symptoms na malapit nang bumigay kapag hard starting sa umaga. suggest you buy multi tester in CDR king to monitor the voltage output of your car batt . the voltage reading should not below 12V otherwise its time to buy a new batt for backup only
    Yup.
    too short
    #192
    Noob question:
    don't worry, po. batteries do not die on the road and the engine stops in the middle of nowhere.. neither do they die at night while raining, leaving you helpless... as long as the engine is running, don't worry about the battery going dead.
    they die in the parking lot or garage.. park 'em that night.. difficult to start the next morning. park 'em in the morning.. hard to start that afternoon.
    master of the push-start.. that's me.
    but i hear, some modern cars may not be push-started anymore..
    sigh..
    i have a battery charger at home.. a must, if one has an AT..
    #193
    Noob question:
    Kaya nga there are signs like hard starting na kahit mainit pa engine, ipa-check na esp. a/t. Check the warranty ng battery, pag malapit na or lumagpas na sa warranty, medyo bantay bantay na.
    Aug 2012
    #194
    sigh..
    Doc! Regarding the charger, are they okay kahit, lets say, 1 or 2 years mong hindi ginagamit yung charger? ehehe What, Where, How much, the charger? :D
    #195
    Quote Originally Posted by slapz View Post
    mas ok yung charger with Trickle function
    I use BOSCH C7 Smart charger
    #196
    we used to have a made-in-usa heavy duty charger.. the one that can start the car. alas, we have misplaced it, over the decades. last i used it was 3 years ago.
    what i have now, is a cheap panther charger i got from the mall. less than 2K. and no, they do not have a projected lifespan. they will probably last longer than the car..
    a trickle charger seems ok, but i don't have the inclination to use one.. hassle..
    a trickle charger is one that you connect to the battery, when your car is going to stay un-used for "long periods of time". it sends a small amount of electricity to the battery; proponents say it prevents the battery from losing charge and going flat. it prolongs the life of the battery, daw.
    Aug 2012
    #197
    I use this automatic battery charger. Can be left connected to car battery indefinitely (weeks, months) without the risk of overcharging.
    Jul 2014
    #198
    I'm using this 5-stage automatic battery charger.
    #199
    Quote Originally Posted by red_one View Post
    Saan ka nakabili and how much sir
    Sep 2010
    #200
    ot - bought a Black n decker 375A jumpstrter kit from Amazon few years ago.
    me tyre inflator na sya + 12v power socket + usb slot.
    buo pa naman hanggang ngyon. kaso madalas iwan ni misis pag sya nagddrive.
Battery life span
