Page 8 of 16 FirstFirst ... 456789101112 ... LastLast
Results 141 to 160 of 306
    Dec 2009
    #141
    ^magkano ang Exide battery? and saan meron?
    cb, keh jawe din... competitor ng amaron...
    mahal na nang amaron pro, yung 3sm na reverese polarity. 6,300... nung binili ko akin before eh 5k lang ata yun( hi-life version). although tagal na nun ahaha.
    yung exide na SF sonic ay 5k ang benta nya... i tried it, bumili ako kahapon... tagal masira nung amaron eh nakakainip kaya nilipat ko sa isang sasakyan na failing na yung nakakabit na battery.. para makasubok ng ibang battery.
    mas mabigat Exide Sf sonic compared sa amaron pro.. probably by around 1-2kgs more...
    nagka interest ako beside the fact na EXIDE gumagawa, eh dahil doon sa "new alloy post grid material" which is sa research ko eh C21 alloy with Barium...
    eh furukawa japan batteries pala nag develop noon... so nasa fore front ng battery development ika nga.. ahahahaha...
    sulit na sulit ako sa amaron, 36 months na eh, hopefully eh mas matagal ito masira. para meh benchmark ako.
    #142
    ^sige, sabihan mo din kami kung ok ba yang Exide na yan. mas maganda kung mas maraming options na cheaper and better quality.
    mga L300 vans namin naka amaron na din lahat hehe so far ok naman in terms of price. benchmark kasi parati is motolite.
    #143
    AT kasi tranny ko bro, and i wouldnt want to have issues that could be avoided by replacing the battery every year. tutal mura lang naman ang kukunin ko na brand new battery kaya OK lang kahit di hi-end.
    any other thoughts?
    any other thoughts?
    wag mo gagawin iyan. nagtry na ako niyan. kinalawang battery holder ko at mabilis kumulo mga ganyang battery. baka wala pang 2 years bulok na ung side ng kaha ng auto mo sa may baterya.
    ended up buying MF free or any "known" at least higher end brands na low maintenance (de-tubig). buti na lang ung holder ng ek lang ang nabulok.
    tsaka, madali na naman express hatid today, kaya no worries na, unless otherwise, magpoprobinsya ka.
    #144
    Quote Originally Posted by RomeoAlpha View Post
    bro confirm ko lang, wag ako bibili ng cheap battery?
    #145
    I wait until the battery is dead. It is easy to push start naman then call motolite. But recently I replaced na without waiting for the batt to die and bought Amaron
    i am impressed!
    very few females even know what push-start means! more so, when one says it's easy (which it is, esp if the car is efi)..
    #146
    that depends.
    you may try a cheap battery, as long as it's not a cheap battery.
    cheap = mura presyo, kumpara sa kumpentensiya. but it's still good quality.
    cheap = inferior quality. designed to maximize profit, at whatever cost.
    some brands do sell a cheaper battery. it's given a different name, so as to avoid paying royalties, and probably, scrimp a bit on the manufacturing, but not too much. but it's still good quality. mine ("champ..." by motolite} was warrantied for 1 year, but it's been over 2 years and still going strong.
    Feb 2009
    #147
    Even the best quality battery will not reach full life expectancy if:
    There is no hold down or the battery is subjected to impact,
    The temperature of the location is always hot,
    The charging system is either overcharging or undercharging,
    There are too many or too much current draw of additional electrical load other than the factory power loads. Too much borloloy strains the charging system,
    And many short stop/start cycles
    #148
    doubledouble.
    #149
    current lead acid auto batteries deteriorate fastest, when they remain "discharged for long periods of time". nabasa ko (understood it, is different) that the sulphides that form during discharge, flake off and cause diminished ability to hold electrical charge.
    the suggestion was, keep the battery fully charged at all times, especially when the vehicle will not be used for long periods of time.
    Aug 2004
    #150
    i am impressed!
    Di ba yan yung button sa dash?
    #151
    Quote Originally Posted by johnm View Post
    di ba yan yung button sa dash?
    hahaha!!
    Feb 2009
    #152
    Push starting a computer controlled engine car will give you a diagnostic trouble code "no STA" signal detected. This is the same circuit as the 50 of the starter
    #153
    but is this standard?
    because i never had such code seen!
    maybe my car isn't "intelligent enough"?
    Feb 2009
    #154
    Or you were using a code reader. A bi-directional scan tool is different
    #155
    perhaps. oh well, i didn't think anymore of it, because the car already started and i got my battery replaced.
    #156
    May nakasubok na ba dito ng Bosch battery, 2SM 95AH daw ayon sa isang FB auto club at sa Amaron dealer din nabili * 5K?
    Apr 2015
    #157
    Tanong lang mga boss,
    yung vios kasi namin 4 years old na, pero hindi pa napapalitan yung battery. Yung battery na gamit ngayon eh yun yung kasama sa kotse noong binili (Motolite Gold). Wala pa naman problema except noong isang beses na medyo matagal umandar kasi matagal ginamit yung radyo sa ACC. Hindi kasi madalas gamitin yung kotse na ito at madalas nasa garahe lang. Dahil marunong na ako magdrive, nakakalabas na ng garahe yung vios. Takot ko lang kasi baka mamaya hindi na lang magstart yung kotse kapag dala ko. Paano ba malaman kung mahina na yung battery? Sa tingin niyo gaano pa tatagal yung battery niya? Short trips lang pala ang takbo ko (Usually 8km lang takbo ko, balikan na yun) tapos pinakamalayo ko naman sa ngayon is 60km balikan.
    Sep 2009
    #158
    Quote Originally Posted by Artur View Post
    4 years is quite good already. malapit na nga yan. Better have the express delivery number of Motolite just in case.
    You can check the voltage of the batter using a voltmeter. If nasa 12V and below na, malapit na yan
    May 2010
    #159
    Minsan sir bigla na lang bumibigay. Like in my last battery replacement, nung umaga ok pa tapos nung paalis na ako ng gabi ayaw na magstart. After fully charging it, di na talaga siya naghohold ng charge. Like what sir Jesto said, keep motolite's express hatid number handy, plus the cash. NS60 motolite gold was around 4k when I got one a couple of weeks ago.
    Oct 2013
    #160
    dalin sa batt shop na may digital batt capacity/life tester, 2015 na meron na tayo ganito technology... sa toyota P175 ang singil nila sa test na ganito...
Battery life span
