Page 75 of 115 FirstFirst ... 256571727374757677787985 ... LastLast
Results 1,481 to 1,500 of 2297
    Sep 2008
    #1481
    By experience, bulge ng battery is caused by overcharging. Calcium deposits especially sa battery post could be a sign of lose terminals. This is not normal
    #1482
    battery bulge is caused by wear-and-tear lead sulphate deposits collecting between the plates, in larger and larger amounts. it is hastened by chronic under-charging.
    white terminal deposits are due to a leak around the battery terminals. these leaks may be caused by housing cracks brought about by improper terminal tightening and loosening techniques.
    they can also be caused by electrolyte (acid) vapors escaping from the battery vents. they are pronounced by overcharging.
    #1483
    that's why i always make it a point with the battery shop guys that never pupukpukin ang terminals every time i buy a new one.
    just pry open the terminal lugs kung medyo masikip.
    Mar 2017
    #1484
    Quote Originally Posted by Lew_Alcindor View Post
    I agree. Yung stock battery ng Innova namin ay Oriental pero 3.5 years itinagal bago nadiskarga for the first time. Pinarecharge ko lang then top-up ng distilled water (pwede ito kahit maintenance free). Obserbahan ko kung ilang buwan itatagal after nung first recharge.
    I agree sir, maganda ang amaron pero marami pang magagandang brand na hindi kilala sa atin. Katulad ng GS battery, stock battery ng Montero SpoSports, naka 4yrs bago napalitan ng bagong battery.
    Apr 2017
    #1485
    Mga sir's tip lang sa pag maintain ng battery nyo, if ever na makakita kayo ng white deposits sa battery terminals esp. in negative terminals, you can clean it with hot water by removing wire terminal and soak it with hot water until white deposits disappear. battery post can be clean with baking soda solution (also with hot water) by using used tootbrush. Reconnect and ensure tightness on battery terminal to ensure longer battery life..
    battery ko DYNA power lang sa monty ko..2 yrs na..
    Oct 2017
    #1486
    Quote Originally Posted by snipers View Post
    Hi sir
    Any tips on taking care of monty stock battery where i need to refill with distilled water ?
    Sent from my SM-G950F using Tsikot Forums mobile app
    Oct 2017
    #1487
    Does amaron battery has free delivery service like motolite ? Where we can get free delivery when batt goes dead
    Jun 2008
    #1488
    Quote Originally Posted by jakewise View Post
    It does not sound right I believe if warranty is dependent on the dealer, just my thought. With my experience with Motolite, all dealers have the same warranty
    As per checking with my friend , sa Province usually shorter ang warranty,
    eg. MOTOLITE in Mindanao is only 12 months even for Motolite EXCEL,
    #1489
    Quote Originally Posted by mbk347 View Post
    now, that is strange...
    batteries, i believe, tend to last longer in the province, what with the traffic-free routes... and longer trips?
    Feb 2017
    #1490
    Joined the Amaron battery team. Gaano na katagal mga Amaron Batteries niyo? Thanks for your time and for sharing 👍🏻
    PAJ 4M40 MORE POWER!
    Sep 2006
    #1491
    Quote Originally Posted by 94mitsukid View Post
    Joined the Amaron battery team. Gaano na katagal mga Amaron Batteries niyo? Thanks for your time and for sharing [emoji1303]
    Still going strong 4 years and 3 months, Amaron Hi life series.
    Sent from my NX529J using Tapatalk
    4 yrs 6 months
    Apr 2008
    #1493
    Ang tatagal na ng inyo. Oldest Amaron battery we bought is a 17 month old Amaron Hi Life 3SM, back in August 6, 2016. Still within 21 month warranty. [emoji38] Excellent battery.
    Sent from my SM-G900I using Tapatalk
    Feb 2017
    #1494
    Quote Originally Posted by GTi View Post
    Thanks sir! Sana tumagal ung akin. Second day pa lang ng akin. Amaron Hi Life Pro. 👍🏻
    Quote Originally Posted by xin View Post
    Wow! Nice sana tumagal ng ganyan ung akin or much longer.
    4 yrs 6 months
    Eto talaga ung post na nagresearch ako sa Amaron battery thanks Ma'am Cathy for asking about Amaron Batteries before. 😊 super sulit na ng bayad sa battery niyo.
    Apr 2008
    #1495
    ^It most likely will, which is why Hyundai gets it for their brand new vehicles.
    Our 2011 Santa Fe which we bought 2nd hand last February 2014 came with a 3SM Amaron battery. Not sure if the 1st owner ever replaced the battery, but we've never replaced it and it still starts fine. So, it would be around 3 years old at the very least, and potentially approaching 7 years old assuming that it is the same battery it came with from the factory. [emoji33]
    #1496
    the battery was probably replaced before you got it.
    koreans are nationalistic.
    May 2005
    #1497
    My Hi-Life 2SM lasted for 3 yrs 3 months
    Annoying is, it just died while I was outside. It didn't give any indication it was about to fail, unlike the previous batteries I had.
    Mar 2004
    #1498
    Use a car voltmeter ...
    #1499
    that's not un-common, po.
    those "warning signs of impending battery failure", just do not occur sometimes.
    pinatay ko engine. after a few minutes, ayaw nang umikit ang starter. buti na lang, MT siya at magaling kaming mag-push-start.
    Apr 2017
    #1500
    What Amaron Hi Life model po needed for Montero Sports? kasi dalawa and model ng 3SMF nila left or right.
Amaron battery
