Results 1,481 to 1,490 of 2247
- Sep 2008
- 587
November 19th, 2017 09:32 PM #1481By experience, bulge ng battery is caused by overcharging. Calcium deposits especially sa battery post could be a sign of lose terminals. This is not normal
- 52,734
November 20th, 2017 01:20 AM #1482battery bulge is caused by wear-and-tear lead sulphate deposits collecting between the plates, in larger and larger amounts. it is hastened by chronic under-charging.
white terminal deposits are due to a leak around the battery terminals. these leaks may be caused by housing cracks brought about by improper terminal tightening and loosening techniques.
they can also be caused by electrolyte (acid) vapors escaping from the battery vents. they are pronounced by overcharging.
November 20th, 2017 03:34 PM #1483
- Mar 2017
- 12
November 27th, 2017 10:49 AM #1484
- Apr 2017
- 14
December 2nd, 2017 07:32 PM #1485Mga sir's tip lang sa pag maintain ng battery nyo, if ever na makakita kayo ng white deposits sa battery terminals esp. in negative terminals, you can clean it with hot water by removing wire terminal and soak it with hot water until white deposits disappear. battery post can be clean with baking soda solution (also with hot water) by using used tootbrush. Reconnect and ensure tightness on battery terminal to ensure longer battery life..
battery ko DYNA power lang sa monty ko..2 yrs na..
- Oct 2017
- 182
December 2nd, 2017 07:45 PM #1486Hi sir
Any tips on taking care of monty stock battery where i need to refill with distilled water ?
Sent from my SM-G950F using Tsikot Forums mobile app
- Oct 2017
- 182
December 2nd, 2017 07:46 PM #1487Does amaron battery has free delivery service like motolite ? Where we can get free delivery when batt goes dead
December 27th, 2017 11:33 AM #1488
- 52,734
December 27th, 2017 12:47 PM #1489
- Feb 2017
- 164
January 9th, 2018 10:05 PM #1490Joined the Amaron battery team. Gaano na katagal mga Amaron Batteries niyo? Thanks for your time and for sharing 👍🏻
PAJ 4M40 MORE POWER!
The serpentine belt is still okay, usual consumables (air filter, oifl filter, cabin filter) got...
Ford Everest 2015
