By experience, bulge ng battery is caused by overcharging. Calcium deposits especially sa battery post could be a sign of lose terminals. This is not normal
battery bulge is caused by wear-and-tear lead sulphate deposits collecting between the plates, in larger and larger amounts. it is hastened by chronic under-charging.
white terminal deposits are due to a leak around the battery terminals. these leaks may be caused by housing cracks brought about by improper terminal tightening and loosening techniques.
they can also be caused by electrolyte (acid) vapors escaping from the battery vents. they are pronounced by overcharging.
Mga sir's tip lang sa pag maintain ng battery nyo, if ever na makakita kayo ng white deposits sa battery terminals esp. in negative terminals, you can clean it with hot water by removing wire terminal and soak it with hot water until white deposits disappear. battery post can be clean with baking soda solution (also with hot water) by using used tootbrush. Reconnect and ensure tightness on battery terminal to ensure longer battery life..
battery ko DYNA power lang sa monty ko..2 yrs na..![]()
Hi sir
Any tips on taking care of monty stock battery where i need to refill with distilled water ?
Sent from my SM-G950F using Tsikot Forums mobile app
Does amaron battery has free delivery service like motolite ? Where we can get free delivery when batt goes dead
Joined the Amaron battery team. Gaano na katagal mga Amaron Batteries niyo? Thanks for your time and for sharing 👍🏻
PAJ 4M40 MORE POWER!
Ang tatagal na ng inyo. Oldest Amaron battery we bought is a 17 month old Amaron Hi Life 3SM, back in August 6, 2016. Still within 21 month warranty. [emoji38] Excellent battery.
Sent from my SM-G900I using Tapatalk
Thanks sir! Sana tumagal ung akin. Second day pa lang ng akin. Amaron Hi Life Pro. 👍🏻
Wow! Nice sana tumagal ng ganyan ung akin or much longer.
Eto talaga ung post na nagresearch ako sa Amaron battery thanks Ma'am Cathy for asking about Amaron Batteries before. 😊 super sulit na ng bayad sa battery niyo.
^It most likely will, which is why Hyundai gets it for their brand new vehicles.
Our 2011 Santa Fe which we bought 2nd hand last February 2014 came with a 3SM Amaron battery. Not sure if the 1st owner ever replaced the battery, but we've never replaced it and it still starts fine. So, it would be around 3 years old at the very least, and potentially approaching 7 years old assuming that it is the same battery it came with from the factory. [emoji33]
My Hi-Life 2SM lasted for 3 yrs 3 months
Annoying is, it just died while I was outside. It didn't give any indication it was about to fail, unlike the previous batteries I had.
What Amaron Hi Life model po needed for Montero Sports? kasi dalawa and model ng 3SMF nila left or right.
