Results 1,551 to 1,560 of 2282
May 8th, 2018 02:16 PM #1551
May 8th, 2018 02:18 PM #1552
Reminder ... NEVER remove / disconnect battery from vehicle while the engine is running ... the car battery acts as a large capacitor to regulate the voltage ...
May 8th, 2018 02:48 PM #1553
- Jan 2018
- 844
May 8th, 2018 03:14 PM #1554That test worked back when cars didn’t have too many electronics. If you pull out the terminal with the engine running, you’re letting your electronics to receive max volts which can end up frying them if they can’t handle it.
Best test is to use a voltmeter. Voltage should read between 13.8 to 15.3 with the engine running and nothing else turned on.
May 8th, 2018 03:31 PM #1555
May 8th, 2018 08:44 PM #1556
May 8th, 2018 09:32 PM #1557
The original Amaron was purchased 3/14/2014, then I claimed warranty August of 2015 (16 months). Replacement was given 9/4/2015, then busted today 5/8/2018 (32 months).
While sulit naman for the total length, it just doesn't live up to the initial hype of longer lifespan (they said nuon last battery for the life of the vehicle).
My stock battery on the Revo lasted 44 months, and we know low end lang mga stock batteries. With Amaron and the hype, I really expected 4 years. Alaga ko pa with distilled water after warranty, and regular charging.
Mag tiyaga uli ako sa hindi mf, kasi ok lang naman mag regular maintenance. Half the price pa. Surely, 2 non-mf units will outlast 1 mf unit (no pun intended - Outlast brand has gone to the dogs).
- 54,207
May 8th, 2018 09:39 PM #1558
May 8th, 2018 10:44 PM #1559
Yup, non-mf lasts longer than mf batteries. Manual topup na lang ng distilled water. Mas mura pa.
Under motolite ba ang outlast? Or a totally different company?
Besides motolite and panasonic, maganda rin ba ac delco or GS batteries??
May 9th, 2018 03:33 AM #1560
Probably looks like a Coke sakto. Yes, where did you buy it?
Fire Extinguisher for Car: what brand and type...
