So this guy last time, removed the terminal to check the condition of the alternator. According to that guy, if the engine dies then the alternator is busted.
If I may go off topic, what's the best way to check the alternator?
That test worked back when cars didn’t have too many electronics. If you pull out the terminal with the engine running, you’re letting your electronics to receive max volts which can end up frying them if they can’t handle it.
Best test is to use a voltmeter. Voltage should read between 13.8 to 15.3 with the engine running and nothing else turned on.
