Ayoko na talaga sa Amaron. My 3smf installed on 9/4/2015 is again dead. Nag lobo na sides. To think this was a replacement unit. And weekly top up with Ctek battery charger.
Panasonic naman.
Panasonic naman.
It just so happened that I'm so used with old models that what I know are somewhat outdated.
For example with this Isuzu I used before, you can actually start it within a battery. I think modern diesel engines won't run with a totally dead battery, much without it, since it needs power to open the solenoid valve for the fuel supply.
Suggested Amazon to a friend... he’s asking if it would have the z4 or h6 type? He said that the group size is 48.
The equivalent in motolite is the d26L but it doesn’t fit in the car’s battery tray and bracket.
Reminder ... NEVER remove / disconnect battery from vehicle while the engine is running ... the car battery acts as a large capacitor to regulate the voltage ...
That test worked back when cars didn’t have too many electronics. If you pull out the terminal with the engine running, you’re letting your electronics to receive max volts which can end up frying them if they can’t handle it.
Best test is to use a voltmeter. Voltage should read between 13.8 to 15.3 with the engine running and nothing else turned on.
Any idea saan makakabili ng amaron battery for altis 2011? May nacheck ako na price 5k sa ibang autoshop. Baka lang may alam kayo na mas mura. Salamat
